pimp559 Posted November 24, 2008 Report Share Posted November 24, 2008 I've gotta pool of oil under the shee that is coming from the water pump cover. What's the fix? Quote Link to comment Share on other sites More sharing options...
2001Stroker Posted November 24, 2008 Report Share Posted November 24, 2008 sounds like it's time to tear down the motor and reseal the cases. and while you're in there....................hmmmm Quote Link to comment Share on other sites More sharing options...
sandman Posted November 24, 2008 Report Share Posted November 24, 2008 Could be that the crankcase breather hose just came off the nipple that's in the lower portion of your water pump area. But most likely it is time for a case splitting session to replace those crank seals. Quote Link to comment Share on other sites More sharing options...
pimp559 Posted November 24, 2008 Author Report Share Posted November 24, 2008 The water pump cover I'm talking about is the little one on the clutch side case where the impeler is. Could that seal be bad allowing oil to come out from under the cover? Quote Link to comment Share on other sites More sharing options...
pimp559 Posted November 25, 2008 Author Report Share Posted November 25, 2008 The water pump cover I'm talking about is the little one on the clutch side case where the impeler is. Could that seal be bad allowing oil to come out from under the cover? I found that the breathertube housing was loose allowing oil to come through. I put some rtv glue on it, waiting for it to dry. :biggrin: Quote Link to comment Share on other sites More sharing options...
