grpark20 Posted November 23, 2008 Report Share Posted November 23, 2008 Todays question is....After you guys put together a fresh engine, how long do you wait before you do a leak down test? Do you do it immediately, let the case sealant dry, wait 24 hrs, or what? Also, do you do the hold 6 psi for 6 minutes with no less than 5 psi at the 6 minute mark or? I interested in what some of the builders do too. Quote Link to comment Share on other sites More sharing options...
278 Posted November 23, 2008 Report Share Posted November 23, 2008 Here call Brandon at Wildcard Racing 435-660-1979, he's been my mentor. Your suppose to run it through the break in heat cycles first before you do it. Here's the process. Assemble and install find out a ball park jetting and run it a little rich just in case, start it up variate the throttle, but dont rev it high or let it idle, until its at opperating temp, it should take about 6-7 minutes or more depending on temp your doing it in, then shut it off and let it cool backj down to normal room/outside temp(wherever you are). Do this 4 times then re-torque all your bolts. Then do a leak down and compression test Quote Link to comment Share on other sites More sharing options...
FASTOYS Posted November 23, 2008 Report Share Posted November 23, 2008 I do the Pressure test when motor assembly is finished. They should hold 6psi for 6 minutes. They say 1psi leakage per minute is acceptable but not in MY shop!! Quote Link to comment Share on other sites More sharing options...
