front shocks
jbones
  • 2 weeks later...
check the for ssale section or ebay for good deal on a used set of works or somethin if all your lookin for is a cheap replacment,
no sense in buying "the best" front shocks if your gona put them on stock witdh a -arms, no matter how good they are it wont handle that great
yea my front shock got stuck down at dumont so i just put it up on the jack and took it off and put it back on upsidedown and it works now
Put it on upsidedown? :confused: I like works, rides much smoother in the trails over stock. You should look into a set of extended a-arms also.
the 2 main ones that guys really like works or elka's. Im getting ready to get some elka's. As far as getting stuck, I know with gas shocks when the temperatures get cold outside like good ways below freezing theyll freeze in whatever position theyre in.
Suspension is one of the best upgrades that you can do to a Banshee. Like MJ said, if you're gonna get some top of the line shocks, you need to compliment them with some good chromoly a-arms.
yea upside down...cuz my shocks had a lil bit of fluid in them but then i turned the one that stuck upsidedown and all the fluid that it has is now oiling the part that goes down in the tube so it works
