Help, Swingarm bolt not coming out
BklynLOD
So I decided to change the bearings on my swingarm. I took off all the bolts and left the big main bolt for last. Took the nut off and tried to push it out and nothing. I started to lube it and again it didn't budge. I banged the shit outta it with a 3lb hammer and still nothing. I think it's rusted right onto the shaft. I can turn the bolt with no problem, but when i go to push it out it doesn't budge. What can I do???????
You have to cut the bolt from the inside of the swingarm, I did the same thing with mine.. Took all of 5 minutes!!! Verses the 3 hours of trying to beat that fucker out!!
Took your advice and cut it off. Came right out. The bearings are stuck in there now. I'm gonna let it soak in some kind of lube penetrant and ordered a bearing puller at work. Hope They don't give me a hard time coming out. I have to buy a bolt from you. I also need The vforce reeds cages. I have the money for them now so let me know.
i would get a can of pb wrench that shit is unreal you spraythe hell uot of it then let it soak then heat it up ,get a big hammer and go to town it will come out just sweet talk it .i had the same problem with mine
