qboronyrican Posted November 20, 2008 Report Share Posted November 20, 2008 (edited) ok this is what i got: 02 shee with 4mill long rod, matched aggresive trail/hillshooter full port job, case matched, t5 pipes, 28mm carbs, cool head pushing 172-174psi, dyna tek cdi on curve 3, adjustable stator +2, v force 3, open air box, 15-41 gearing with stock swingarm, extended arms and 21's on the rear tires................................would like to know what i need to do to hook up and get some good traction.......i ride in a lot of dirt trails open and tight and coal hills and fields....alot of head to head racing on those surfaces too......so what do i got to do.....gearing, swingarm, what! help me here Edited November 20, 2008 by qboronyrican Quote Link to comment Share on other sites More sharing options...
06shee325 Posted November 20, 2008 Report Share Posted November 20, 2008 ok this is what i got: 02 shee with 4mill long rod, matched aggresive trail/hillshooter full port job, case matched, t5 pipes, 28mm carbs, cool head pushing 172-174psi, dyna tek cdi on curve 3, adjustable stator +2, v force 3, open air box, 15-41 gearing with stock swingarm, extended arms and 21's on the rear tires................................would like to know what i need to do to hook up and get some good traction.......i ride in a lot of dirt trails open and tight and coal hills and fields....alot of head to head racing on those surfaces too......so what do i got to do.....gearing, swingarm, what! help me here Subscribing...... all i know is shees dont hook worth a damn. Quote Link to comment Share on other sites More sharing options...
hercalmighty Posted November 20, 2008 Report Share Posted November 20, 2008 What kind of tires? If you want traction go with a minus swing arm but then you will be standing the thing up alot Quote Link to comment Share on other sites More sharing options...
Trick2stroke Posted November 20, 2008 Report Share Posted November 20, 2008 Go shorter with the swinger, overall better handling loads more traction and it's still managable. It won't be standing on end like you might think.One of my all time favorit mods for the stock chassis shee. Quote Link to comment Share on other sites More sharing options...
wacko2000 Posted November 20, 2008 Report Share Posted November 20, 2008 Its all in your launch bro, I have some mods to my shee as-well, and i launch out of the hole pretty dam good, All my 4poker buddies cant understand why they cant even beat me out of the hole, never mind once we hit 3-4 gear. Practice you launches when your by yourself and i promise you'll get good. I went from a +2 swinger 15/41 gearing back to a stock swinger/ stock gearing 20" razr in the rear. Is you rear shock stock? are you running race gas bc thats alot of compression.. joseph Quote Link to comment Share on other sites More sharing options...
qboronyrican Posted November 21, 2008 Author Report Share Posted November 21, 2008 yea running 50/50 race gas and 93 pump and yea the rear shock is stock but recently rebuilt Quote Link to comment Share on other sites More sharing options...
