Jetting for 34mm keihin
1.6i
So my buddy blew his engine in glamis halloween weekend..long story short he went and bought some 34mm keihin carbs online (dont know what model yet) and we need some base line start on jetting.. mods are as follows:
34mm carbs assuming pwk's not sure yet
pods
wiseco 65mm bore/stock crank
cool head 21cc domes
fmf fattys
timing @+2
V-force 3
stock port
sea level
are these carbs too big for his setup?
where should we start the mains, pilots and needles at?
i only have experience with stock carbs so far..so i need some schooling
thanks in advance
Yea I would say they are to big for a stock ported machine. I would get a port job instead of getting rid of the carbs.
You kind of need to know the moddle of the carb because PJ's and PWK's do jet a little different.
I will assume they are PJ's since they are 34mm. Your really going to need a carb sync tool because you set the Idle by turing the choak knob.
I would start out in the is range.
main 155
needel CEK middle clip
pilot 50 or 48
When I had PJ's before my PWK's the PJ's seemed to like a little richer bottom end. If your going on a trip I would probably take main jet sizes 158-148 and pilot jet sizes 52-45 and a pair of CEK and CEL needles.
josh
