anyone use liquad gasket or similar product
My hipers dont leak. Stupid question but are you tightening them enough? I have no oring.? Do you mean on the valve stem?
marinenyc,
in your sig if you look at your front tires there are two rings of bolts. the bigger of te two is the one that holds the ring and the smaller of the two is the one that holds the billet part of the wheel to the carbon fiber part. with in the smaller ring of bolts there are two rubber o-rings that seal it. thats where the leak is and thats where i was thinking of using the liq. gasket on. you dont have any o rings there?
thanks
peter
permatex ultra grey would be about the only thing I would use. I use it on my ITP beadlocks because it is the only thing Ive found to hold.
I used this on my big block for the front and rear intake gaskets, with 13.5:1 compression. It built up alot of crank pressure, since I never installed an evacuation system. It would blow the gaskets right out everytime I started it, but the Permatex was a one time installation. Held up until I sold the engine.
AH!! Ok Ty ive never had them apart there. Yea buy new O rings. Like LOCO said. We used to try all type of sealers when I worked on HELOs. Never worked out the rright way. Try this . We used to coat the o rings in vasalein (petrolium jelly) and that used to help them stay in place and create the initial seal. Im telling you the truth. It sounds funny but is a proven trick. :thumbsup:
sweet trick ill try it
thanks
We do this on Super Hornets on the hydraulic system components as well and it works quite well.
