tnGRbanshee Posted November 15, 2008 Report Share Posted November 15, 2008 does anyone have any pics. or info about porting reed cages .where exactly do you remove material from?any advice would be appreciated. Quote Link to comment Share on other sites More sharing options...
05.Banshee.SE Posted November 15, 2008 Report Share Posted November 15, 2008 I have a set of stock cages and a set of ported stock cages. Some guy ported the ported cages I have...and they look pretty bad. I'd be interested in seeing how it's supposed to look also. Quote Link to comment Share on other sites More sharing options...
278 Posted November 15, 2008 Report Share Posted November 15, 2008 Your biggest change will be in the heighth what you want to do is use whatver petals your planning on running or the stock ones as your template. Remove material from around each port until you have just a little bit holding each petal on. With the top of each port you go up to about 1/2cm. below the screw hole. sorry no pics, but like I told 05. just need to practice. I recomend using a triangular file and if you want to speed up the process a dremel with a carbide cutting tip... be careful when using the dremel though you dont want to take out too much. If you still have questions call Brandon at Wildcard Racing he can help you, he's a great guy to work with 435-660-1979 Quote Link to comment Share on other sites More sharing options...
05.Banshee.SE Posted November 16, 2008 Report Share Posted November 16, 2008 I might try messing around and filing those stockers down... The file should allow me to not mess it up to bad, lol, and when I can't make it to the shop to work on my bike I sit at home with nothing. :happy: Quote Link to comment Share on other sites More sharing options...
Tedder Posted November 16, 2008 Report Share Posted November 16, 2008 does anyone have any pics. or info about porting reed cages .where exactly do you remove material from?any advice would be appreciated. Don't know if this link will work or if you'll have to log into ATV Drag Racing Assoc but Tony Doukas posted some pretty good info on the subject. http://www.atvdra.com/forums/thread-view.a...s=1&start=1 Quote Link to comment Share on other sites More sharing options...
tnGRbanshee Posted November 16, 2008 Author Report Share Posted November 16, 2008 Don't know if this link will work or if you'll have to log into ATV Drag Racing Assoc but Tony Doukas posted some pretty good info on the subject.http://www.atvdra.com/forums/thread-view.a...s=1&start=1 thank alot that was exactly what i was looking for Quote Link to comment Share on other sites More sharing options...
