01banch Posted November 11, 2008 Report Share Posted November 11, 2008 Ok so im going to buy a +4 swingarm, Ive heard i want to get a roundhouse swingarm, I am assuming Im going to need a new bearing carrier to make this work? If so generally how much is it to buy the carrier and how much work is it to swap the axle into the new carrier? Quote Link to comment Share on other sites More sharing options...
Wildcardracing Posted November 11, 2008 Report Share Posted November 11, 2008 Yes, you will need to get a new bearing carrier for your roundhousing swingarm. You can get nice one from jjandaracing.com, look in thier garage sale section. They sell rebuilt ones in that section, I have purchased a couple there and I couldn't tell either weren't brand new. All you have to do is remove your left hub and the axle lock nuts then slide the axle out to the right. They can be a pain if the axle has rusted in place, you can use a dead blow hammer and a piece of 2x4 to pound it out. Quote Link to comment Share on other sites More sharing options...
01banch Posted November 11, 2008 Author Report Share Posted November 11, 2008 thx for the input :biggrin: Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted November 11, 2008 Report Share Posted November 11, 2008 depending on what brnad and where u buy the swinger, it may already come with a carrier... Also if you buy a carrier make sure you gte the right size, JJ&A will have 40mm carriers forsale in that garage section, unless your running a drag axle you need to get the 35mm carrier. Quote Link to comment Share on other sites More sharing options...
