garhettbanshee Posted November 9, 2008 Report Share Posted November 9, 2008 Ok so i went to dumont this holloween with my banshee and my girls. I rode her bike up the hills a couple times it ran great. Well it rained saturday and when i was going up comp hill i noticed her bike had a hard time getting asnd staying in the powerband like it was cutting in and out. Well i have gone through the carb(2 in to 1) twice ,changed plugs, changed cdi, changed coil, checked voltage regulator, and she ran better after i cleaned the caRb i even ran it without the filter and she did better but still spuddered at the top end any ideas? I checked aLL grounds and wire connections i even sanded the rust off the stator does anyone know whats up? maybe a pipe is clogged? She runs fine low mid and a little high range but not full throttle top end she still feals like she is spuddering and popping. Keep in mind i havent changed the jets but it ran fine with the same ones before the rain idk maybe gas with water? anyideas please help!!!! Quote Link to comment Share on other sites More sharing options...
THE GRIM RIPPER Posted November 9, 2008 Report Share Posted November 9, 2008 The level of humidity will affect the air bigtime.... This has happened to alot of guys on here. If your jets are spot on and you know that for a fact... Chalk it up to bad conditions and try running on a less humid day Go from there Quote Link to comment Share on other sites More sharing options...
garhettbanshee Posted November 9, 2008 Author Report Share Posted November 9, 2008 The level of humidity will affect the air bigtime.... This has happened to alot of guys on here. If your jets are spot on and you know that for a fact... Chalk it up to bad conditions and try running on a less humid day Go from there I am in vegas now trying to figure it out no rain here man i am stumped lol Quote Link to comment Share on other sites More sharing options...
2001Stroker Posted November 9, 2008 Report Share Posted November 9, 2008 Maybe you have a small air leak that only sucks air when the engine is really sucking alot of vacuum. Check the intake gaskets and carb boot. How do your plugs look? If you have a leakdown tester, maybe check that too. You ain't losing any tranny fluid, are you? Quote Link to comment Share on other sites More sharing options...
garhettbanshee Posted November 9, 2008 Author Report Share Posted November 9, 2008 Maybe you have a small air leak that only sucks air when the engine is really sucking alot of vacuum. Check the intake gaskets and carb boot. How do your plugs look? If you have a leakdown tester, maybe check that too. You ain't losing any tranny fluid, are you? No but i dont think she has a leak either im thinking a pipe is clogged she sounds like shes starving for air and gas when you really open her up Quote Link to comment Share on other sites More sharing options...
shogs Posted November 9, 2008 Report Share Posted November 9, 2008 Have you replaced your silencer packing lately? I just changed mine today and it made a huge difference. Quote Link to comment Share on other sites More sharing options...
firebanshee Posted November 9, 2008 Report Share Posted November 9, 2008 Sounds to me like you could possibly need to change your spark plug boots,your resistor could be blown. Quote Link to comment Share on other sites More sharing options...
garhettbanshee Posted November 9, 2008 Author Report Share Posted November 9, 2008 Have you replaced your silencer packing lately? I just changed mine today and it made a huge difference. It could be the packing but i changed the plugs and caps it still does it Quote Link to comment Share on other sites More sharing options...
THE GRIM RIPPER Posted November 9, 2008 Report Share Posted November 9, 2008 I highly doubt its the packing Quote Link to comment Share on other sites More sharing options...
J-Madd Posted November 9, 2008 Report Share Posted November 9, 2008 You didn't mention changing the stator. You've pretty much ruled everything else out. I had a stator go bad and did exactly what you describe. I don't think the the boots have resistors do they??? Quote Link to comment Share on other sites More sharing options...
garhettbanshee Posted November 9, 2008 Author Report Share Posted November 9, 2008 You didn't mention changing the stator. You've pretty much ruled everything else out. I had a stator go bad and did exactly what you describe. I don't think the the boots have resistors do they??? her spark plugs are br9s and they have resistors in them herlights work fine so i don't think its the stator. i cant figure it out this is frustrating Quote Link to comment Share on other sites More sharing options...
05.Banshee.SE Posted November 9, 2008 Report Share Posted November 9, 2008 I ran my bike on a really high humidity night... it pretty much boiled over, and I coulda sworn the damn top end was junked (because I ran through EVERYTHING and nothing fixed it.) Week later, after flushing some fluids and stuff, after the temp changed, 'Shee ran sweet again. Quote Link to comment Share on other sites More sharing options...
J-Madd Posted November 9, 2008 Report Share Posted November 9, 2008 her spark plugs are br9s and they have resistors in them herlights work fine so i don't think its the stator. i cant figure it out this is frustrating Resistors are in the PLUGS not boots,,,and the lighting coil is different from the part that fires the plugs. You can have lights and a bad stator. Quote Link to comment Share on other sites More sharing options...
garhettbanshee Posted November 9, 2008 Author Report Share Posted November 9, 2008 Resistors are in the PLUGS not boots,,,and the lighting coil is different from the part that fires the plugs. You can have lights and a bad stator. wellif it was a bad stator it seems to be working fine now i think it was gas with water because i drained the tank and blew out everything and she seems to only do it every three runs now. so idk any ideas? Quote Link to comment Share on other sites More sharing options...
J-Madd Posted November 9, 2008 Report Share Posted November 9, 2008 wellif it was a bad stator it seems to be working fine now i think it was gas with water because i drained the tank and blew out everything and she seems to only do it every three runs now. so idk any ideas? Stators will act up at random unfortunately, making problems difficult to diagnose. Quote Link to comment Share on other sites More sharing options...
