T-daddy Posted November 9, 2008 Report Share Posted November 9, 2008 How do u know when your plugs are fouled do your bike smoke alot more then normal what are the symptoms? Quote Link to comment Share on other sites More sharing options...
gumby6t9 Posted November 9, 2008 Report Share Posted November 9, 2008 When you foul a plug it wont spark and your engine won't run. Quote Link to comment Share on other sites More sharing options...
T-daddy Posted November 9, 2008 Author Report Share Posted November 9, 2008 When you foul a plug it wont spark and your engine won't run. oh ok then im good mine starts 1-3 kicks Quote Link to comment Share on other sites More sharing options...
T-daddy Posted November 9, 2008 Author Report Share Posted November 9, 2008 oh ok then im good mine starts 1-3 kicks another question on one of my plug caps the top of the plug is stuck inside of it how can i get that little metal tip out of the plug cap Quote Link to comment Share on other sites More sharing options...
AKheathen Posted November 9, 2008 Report Share Posted November 9, 2008 (edited) another question on one of my plug caps the top of the plug is stuck inside of it how can i get that little metal tip out of the plug cap pull your plugs out and check them! they should be light brown on the ceramic and dry. then screw the one back into the tip and pull it out of the cap :thumbsup: you may have to push and turn to get it to screw back in. and excessive smoke is usually cheap oil, old/bad gas, or plugged air filter. Edited November 9, 2008 by AKheathen Quote Link to comment Share on other sites More sharing options...
T-daddy Posted November 9, 2008 Author Report Share Posted November 9, 2008 pull your plugs out and check them! they should be light brown on the ceramic and dry. then screw the one back into the tip and pull it out of the cap :thumbsup: you may have to push and turn to get it to screw back in. and excessive smoke is usually cheap oil, old/bad gas, or plugged air filter. thats exactly what i needed to no / and i use yamalube 2r but it smells horrible im gonna switch to castor 927 but my gas is kinda old im gonna mix up a fresh batch and see how it runs thanks Quote Link to comment Share on other sites More sharing options...
ClimbAnyHill Posted November 9, 2008 Report Share Posted November 9, 2008 Run it with the fresh gas first so you can really see how it performs. Use the old has later if you must.. Quote Link to comment Share on other sites More sharing options...
flyhighprerunner Posted November 9, 2008 Report Share Posted November 9, 2008 Correction use that old gas to start the fire but to get the spark plug top off just try needle noses or get another plug screw it in the plug end and pull it out! Quote Link to comment Share on other sites More sharing options...
T-daddy Posted November 9, 2008 Author Report Share Posted November 9, 2008 Correction use that old gas to start the fire but to get the spark plug top off just try needle noses or get another plug screw it in the plug end and pull it out! i tried screwing the plug iin and it screwed in but i cant seperate the plug and the cap its on there pretty good any ideas on how to pull it apart Quote Link to comment Share on other sites More sharing options...
2001Stroker Posted November 9, 2008 Report Share Posted November 9, 2008 Pull harder. It should come out. Quote Link to comment Share on other sites More sharing options...
T-daddy Posted November 9, 2008 Author Report Share Posted November 9, 2008 Pull harder. It should come out. ok got it out taped it out with small hammer :woot: for the help guys Quote Link to comment Share on other sites More sharing options...
05.Banshee.SE Posted November 9, 2008 Report Share Posted November 9, 2008 How often are you guys changing plugs out anyways? JW Quote Link to comment Share on other sites More sharing options...
2001Stroker Posted November 9, 2008 Report Share Posted November 9, 2008 How often are you guys changing plugs out anyways? JW I usually change mine about every 6 months, just cause I'm anal. I do it in my car, too. If your jetting is right and you don't use over-excessive amounts of oil, you should be able to run on the same plugs like it's a 4-stroke. They should last for a very long time, and SHOULDN'T ever foul. Quote Link to comment Share on other sites More sharing options...
05.Banshee.SE Posted November 9, 2008 Report Share Posted November 9, 2008 I usually change mine about every 6 months, just cause I'm anal. I do it in my car, too. If your jetting is right and you don't use over-excessive amounts of oil, you should be able to run on the same plugs like it's a 4-stroke. They should last for a very long time, and SHOULDN'T ever foul. Thanks for the info man. I've yet to foul a plug, and haven't had any plug problems *knock on wood*.... Apparently I'm even more anal, because I change out plugs about bi-monthly or so. I don't have to, but I'm usually ordering parts anyways so I throw a new set of plugs in, and keep all the oldies together (that are still good.) NGK must love my ass. Since I've been modding my bike so much lately, and dialing it in all the time, I have plug chopped what NGKs South American plants have produced in the last 6 months. JK JK :biggrin: Quote Link to comment Share on other sites More sharing options...
