pro design cool head domes
glk45
i am wondering what is the smallest CC dome i can safely run on my bansh? right now i am running 21cc domes and i run on vp110 octane fuel. i would like to try out some 18 or 19 cc domes but i dont want to kill the bottom end of my motor. i dont have any motor work done.. one of my buds has 20cc domes and i need to out do him!!! thanx for any help
Do a compression test so we know where you are with the 21's. I can tell you that you are losing hp with the 110 if you are under @170 psi static compression. 21's at sea level should only require 100 octane even with a +4 timing advance. I don't recommend running high compression above 160 untill you true/weld your crank. By the way welcome to the HQ
