4stroker Posted November 6, 2008 Report Share Posted November 6, 2008 With my Keihin 33 Quote Link to comment Share on other sites More sharing options...
dajogejr Posted November 6, 2008 Report Share Posted November 6, 2008 Stick your finger in the back of the carb, see if you can push the slide up any further...if you can't, it's WOT. Looks like that should go up a bit more.. Quote Link to comment Share on other sites More sharing options...
FASTOYS Posted November 6, 2008 Report Share Posted November 6, 2008 Like Dajog said, and you may need some taller adjusters. I would also recommend you check your boost bottle for leaks/air leaks. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted November 6, 2008 Report Share Posted November 6, 2008 It is also possible if that cable is old that it's strectched out a bit...as well. Quote Link to comment Share on other sites More sharing options...
J-Madd Posted November 6, 2008 Report Share Posted November 6, 2008 Also, get rid of the stop on the thumb throttle if you haven't already. Quote Link to comment Share on other sites More sharing options...
desertdeweller Posted November 6, 2008 Report Share Posted November 6, 2008 I think fast sells a kit for that problem taller adjusters and springs something to that effect. I have read about it before that the regular adjusters aren`t tall enough Quote Link to comment Share on other sites More sharing options...
4stroker Posted November 6, 2008 Author Report Share Posted November 6, 2008 Like Dajog said, and you may need some taller adjusters.I would also recommend you check your boost bottle for leaks/air leaks. yep i tried and tried and i cant get em to go any higher with the stock (keihin) adjusters. the cable is a new motion pro. looks like ill have to find or make some taller ones. yeah the pro design intakes arent worth a shit.. it has leaked on me before thats why it is siliconed up to the max in that pic... i have a boss intake on my other engine and it is the bomb. i am fixin to get one to replace this busted ass pro design. thanks for your help fellas, mark Quote Link to comment Share on other sites More sharing options...
jayzx10r Posted November 6, 2008 Report Share Posted November 6, 2008 I have a set of the PWK33's and the slide goes ALL the way up out of view!! In fact, that is how I sync my carbs... All the way open at the lip is a point I can repeat on both carbs for perfect balance. :thumbsup: I'm sure no one will disagree with me on the sync thing........uh~huh. Quote Link to comment Share on other sites More sharing options...
