caddyman Posted November 5, 2008 Report Share Posted November 5, 2008 So I am going to start working on my 2000 Shee my boy rides. Last time out it got stuck in second gear. He was hill climbing and I guess when he shifted to second the foot lever went wayyyy up, and was hard to get to neutral. So we tinkered a bit and continued to ride, was o.k. for a few......then he couldn't get anything other than second. Totally stuck now, we can't find anything at all. So where should I start? I have not had a chance to do anything yet with it so I figured I'd get your guy's opinion on where to look. Thanks......... Quote Link to comment Share on other sites More sharing options...
pabansheematt Posted November 5, 2008 Report Share Posted November 5, 2008 So I am going to start working on my 2000 Shee my boy rides. Last time out it got stuck in second gear. He was hill climbing and I guess when he shifted to second the foot lever went wayyyy up, and was hard to get to neutral. So we tinkered a bit and continued to ride, was o.k. for a few......then he couldn't get anything other than second. Totally stuck now, we can't find anything at all.So where should I start? I have not had a chance to do anything yet with it so I figured I'd get your guy's opinion on where to look. Thanks......... Start by checking the spring on the end of the shift shaft. I had a similar problem and a new shift shaft fixed it. Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted November 6, 2008 Report Share Posted November 6, 2008 IF THE FOOT LEVER MOVED UP, THEN THE SHIFT SHAFT IS BENT, AND THE RETAINER PRONGS THAT GO ON THE SHIFT STAR PEGS ARE NO LONGER CONTACTING. Quote Link to comment Share on other sites More sharing options...
C&B Posted November 6, 2008 Report Share Posted November 6, 2008 ditto shift shaft is shot Quote Link to comment Share on other sites More sharing options...
caddyman Posted November 6, 2008 Author Report Share Posted November 6, 2008 IF THE FOOT LEVER MOVED UP, THEN THE SHIFT SHAFT IS BENT, AND THE RETAINER PRONGS THAT GO ON THE SHIFT STAR PEGS ARE NO LONGER CONTACTING. Jeeez, Snop.....quit yellin at me! LOL....your caps are on.... O.k. so I'll tear into it tomorrow, pretty easy to check and replace???? Pull shifter/ side cover, or do I have to tear down more??? I just need to get a maunual finally.... Quote Link to comment Share on other sites More sharing options...
spurdy Posted November 6, 2008 Report Share Posted November 6, 2008 Jeeez, Snop.....quit yellin at me! LOL....your caps are on.... O.k. so I'll tear into it tomorrow, pretty easy to check and replace???? Pull shifter/ side cover, or do I have to tear down more??? I just need to get a maunual finally.... I am pretty sure the clutch basket has to come out to remove the shift shaft. SP Quote Link to comment Share on other sites More sharing options...
clinton588 Posted November 6, 2008 Report Share Posted November 6, 2008 You have to pull off the foot peg, kick starter, clutch cover, kick starter set up, clutch, clutch basket, then you can get to the shift arm. The spring more then likely poped out of the arm. Just put it back in and check the adjustment on the clutch arm with the shift star. Also check the adjuster bolt for the shift arm, if it is broke that will also do it. Quote Link to comment Share on other sites More sharing options...
caddyman Posted November 6, 2008 Author Report Share Posted November 6, 2008 You have to pull off the foot peg, kick starter, clutch cover, kick starter set up, clutch, clutch basket, then you can get to the shift arm. The spring more then likely poped out of the arm. Just put it back in and check the adjustment on the clutch arm with the shift star. Also check the adjuster bolt for the shift arm, if it is broke that will also do it. Thanks Clinton.....huge help right there. I wonder if I should throw in a modded shift star.......... Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted November 6, 2008 Report Share Posted November 6, 2008 The caps were on from quickbooks at work. I didn't feel like retyping it. Quote Link to comment Share on other sites More sharing options...
tapout94 Posted November 6, 2008 Report Share Posted November 6, 2008 (edited) go look up cascade innovations out of oregon and order a mod shift star and shift pro shift kit. you can order online or by phone. you'll love it!! as far as your shifting... i does sound like the shift shaft, if not... you will have to dig deeper, next check the shift forks for wear or bending and the shift drum for wear. but..... if your not quite sure what all it intails, buy a clymers manual. best investment i have made towards my shee yet! Edited November 6, 2008 by tapout94 Quote Link to comment Share on other sites More sharing options...
fast500#12 Posted November 6, 2008 Report Share Posted November 6, 2008 i had a similar thing happen on mine a while back the shift adjuster cam screw broke. its all the same tear down so have fun. Quote Link to comment Share on other sites More sharing options...
maxtrax Posted November 7, 2008 Report Share Posted November 7, 2008 I am having a similar problem this morning. I was out bustin around and couldn't get it any lower than 5 but could shift 5-6 just fine. I managed to get it back home, and with 10 min of playing with it managed to find neutral. Would you guys say I have a similar problem with the shift shaft. FYI - I recently replaced the broken eccentric adjuster stud and readjusted it, haven't had any problems, but now I am having this problem. Quote Link to comment Share on other sites More sharing options...
clinton588 Posted November 8, 2008 Report Share Posted November 8, 2008 go look up cascade innovations out of oregon and order a mod shift star and shift pro shift kit. you can order online or by phone. you'll love it!! as far as your shifting... i does sound like the shift shaft, if not... you will have to dig deeper, next check the shift forks for wear or bending and the shift drum for wear. but..... if your not quite sure what all it intails, buy a clymers manual. best investment i have made towards my shee yet! Not to down any parts any parts but I have a 02 Shee with all the stock clutch & shifter parts, with the excipton of Barnett HD springs. We tryed The shift star & shift pro in a bike that was hard to shift and the shift pro broke in about 10 hrs of riding. So what I'm saying is fix the problem first b4 you go spending money that won't fix the problem. After the problem is fixted then if you want to try something new it would be cool. Every bike is different some parts work and some don't. Quote Link to comment Share on other sites More sharing options...
clinton588 Posted November 8, 2008 Report Share Posted November 8, 2008 I am having a similar problem this morning. I was out bustin around and couldn't get it any lower than 5 but could shift 5-6 just fine. I managed to get it back home, and with 10 min of playing with it managed to find neutral. Would you guys say I have a similar problem with the shift shaft. FYI - I recently replaced the broken eccentric adjuster stud and readjusted it, haven't had any problems, but now I am having this problem. Is it shifting good now? If not pull your clutch cover off and look at your little spring on the shift arm behind the clutch basket. If not that check the adjuster stud to make sure it is ok. Quote Link to comment Share on other sites More sharing options...
tapout94 Posted November 8, 2008 Report Share Posted November 8, 2008 Not to down any parts any parts but I have a 02 Shee with all the stock clutch & shifter parts, with the excipton of Barnett HD springs. We tryed The shift star & shift pro in a bike that was hard to shift and the shift pro broke in about 10 hrs of riding. So what I'm saying is fix the problem first b4 you go spending money that won't fix the problem. After the problem is fixted then if you want to try something new it would be cool. Every bike is different some parts work and some don't. guess my shift pro kit must be the one exception..... Quote Link to comment Share on other sites More sharing options...
