grpark20 Posted November 2, 2008 Report Share Posted November 2, 2008 I recently yook apart my stock thumb throttle to get it all powder coated. I'm such an idiot for not taking pictures before disassembling. I need to know how to put the throttle back together. Also, do you have to keep the spring inside the thumb throttle assembly.....trying to save the thumb. I'll be adding Jeff's springs, fresh cable, and cascade extender. Pictures would be very, very helpful if anyone has them. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
vulvafan537240 Posted November 3, 2008 Report Share Posted November 3, 2008 dont have a pic but heres an eploded view of the throttle assy http://partsfinder.onlinemicrofiche.com/Al...;A=152&B=32 Quote Link to comment Share on other sites More sharing options...
grpark20 Posted November 3, 2008 Author Report Share Posted November 3, 2008 dont have a pic but heres an eploded view of the throttle assy http://partsfinder.onlinemicrofiche.com/Al...;A=152&B=32 Thanks! That answeres most of my questions. Next info needed is do I have to run the spring and lever that the spring goes on? I read one post that said it is not needed unless you are running TORS. Is this fact or opinion? Quote Link to comment Share on other sites More sharing options...
2001Stroker Posted November 3, 2008 Report Share Posted November 3, 2008 Thanks! That answeres most of my questions. Next info needed is do I have to run the spring and lever that the spring goes on? I read one post that said it is not needed unless you are running TORS. Is this fact or opinion? Keep the spring in there. If you want it lighter, cut a coil or so off the springs in the carbs. Quote Link to comment Share on other sites More sharing options...
BellicoseBanshee Posted November 3, 2008 Report Share Posted November 3, 2008 Keep the spring in. :thumbsup: Quote Link to comment Share on other sites More sharing options...
grpark20 Posted November 3, 2008 Author Report Share Posted November 3, 2008 Ok.....I'm a dumbass.......I already tossed the spring. Will it hurt not to run it, or should I stop being cheap and buy another spring? I've heard of others not running it, but I want to do it semi-right. Quote Link to comment Share on other sites More sharing options...
grpark20 Posted November 6, 2008 Author Report Share Posted November 6, 2008 I got the Cascade thumb throttle extender today. The directions state that you DO NOT need the spring if the TORS are deactivated. Hope it helps someone out. It's a quality looking piece too!! Quote Link to comment Share on other sites More sharing options...
