m barrett Posted November 2, 2008 Report Share Posted November 2, 2008 when you first start it up there is a ratling noise you can hear it on both sides just as loud when you rev it up nothing changes but after you ride it for a little bit you can barley hear it i just rebuilt it and it did not help it could it be a bad bearing Quote Link to comment Share on other sites More sharing options...
sinisterboo Posted November 2, 2008 Report Share Posted November 2, 2008 maybe take a video or sound clip of it, maybe someone will be able to help you then..... Quote Link to comment Share on other sites More sharing options...
2001Stroker Posted November 2, 2008 Report Share Posted November 2, 2008 If you have a mechanic's stethoscope, see if you can pin-point it. If not, just use a 3/8" really long extension, and stick one end in your ear and the other end all over the engine until you find the noise. I have a loud knock coming from both sides of my intake. Not the reeds, carbs, or the jug, but the intake. Originally, I thought it was a rod knock. But there isn't any noise in the rotating assembly. I can't figure out why it makes that noise, but it won't go away. It's hard to ignore, but I still ride the piss out of it. My engine started making that noise about 5 hours into the break-in. It was brand new when it started. Quote Link to comment Share on other sites More sharing options...
