brian Posted November 6, 2008 Report Share Posted November 6, 2008 You might check that little drain screw that intersects the overflow tube I had one leaking there once after a rebuild. Just didn't get it clean enough in the seat area. If thats not it, you may have a bad float. I had one get a little leak in the seam and it would get some fuel inside making it a little heavier. It would not let the seat to close all the way, especially after hitting alot of bumps. Quote Link to comment Share on other sites More sharing options...
