OKCterror Posted November 2, 2008 Report Share Posted November 2, 2008 I just installed twin pods, milled head, fmf fatties into powercore cans, and running 91 pump. Which jets should i use. It will start but have to play with the gas to keep it running. and it wont rev up without dying. Help please-Dan Quote Link to comment Share on other sites More sharing options...
gusrod1580 Posted November 2, 2008 Report Share Posted November 2, 2008 I just installed twin pods, milled head, fmf fatties into powercore cans, and running 91 pump. Which jets should i use. It will start but have to play with the gas to keep it running. and it wont rev up without dying. Help please-Dan Buy some 27.5 and 30 pilots, and i'd say 300,310,320 mains and just trial and error, try a combo if it doesnt work try another till you get it right. start out at 27.5 pilot and 300 main and go from there. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted November 2, 2008 Report Share Posted November 2, 2008 what carbs and what was the jetting before you did all this? Quote Link to comment Share on other sites More sharing options...
OKCterror Posted November 2, 2008 Author Report Share Posted November 2, 2008 stock carbs and i was at like a 300 main Quote Link to comment Share on other sites More sharing options...
OKCterror Posted November 4, 2008 Author Report Share Posted November 4, 2008 scratch that, 290 main. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted November 4, 2008 Report Share Posted November 4, 2008 27.5 pilot and start with 320 main. Quote Link to comment Share on other sites More sharing options...
OKCterror Posted November 4, 2008 Author Report Share Posted November 4, 2008 when i screw the pilot all the way in how many turns to i screw it out? Quote Link to comment Share on other sites More sharing options...
brian Posted November 4, 2008 Report Share Posted November 4, 2008 Thats the idle mixture screw. It is an air screw (adds air as you open it). Gently screw it all the way in, and back it out 1.5 to 2 turns. Once it is idling you can fine tune it. Quote Link to comment Share on other sites More sharing options...
OKCterror Posted November 4, 2008 Author Report Share Posted November 4, 2008 do i have to adjust the c clip over the main needle at all when i add the new jets? Quote Link to comment Share on other sites More sharing options...
brian Posted November 4, 2008 Report Share Posted November 4, 2008 Start with clip in the center groove and work from there. Get the idle mix and speed syncrinized first. Then check main at wot......plug chop. Then adjust clip position if needed. Quote Link to comment Share on other sites More sharing options...
OKCterror Posted November 4, 2008 Author Report Share Posted November 4, 2008 picked up 2 310's and was told to turn the air mix to 2 1/4 turns out. Going from there Quote Link to comment Share on other sites More sharing options...
OKCterror Posted November 4, 2008 Author Report Share Posted November 4, 2008 bike runs bad ass, 1 problem that is always coming back. The overflow tube is dripping gas again. I adj the floats per you guys and clymers and cleaned and synced both properly. It really only drips after riding hard or coming to a stop really fast. Any advice???? Quote Link to comment Share on other sites More sharing options...
brian Posted November 4, 2008 Report Share Posted November 4, 2008 prolly have a bad needle/seat at the inlet. Quote Link to comment Share on other sites More sharing options...
OKCterror Posted November 5, 2008 Author Report Share Posted November 5, 2008 (edited) no there all new, had everything replaced twice Edited November 5, 2008 by OKCterror Quote Link to comment Share on other sites More sharing options...
OKCterror Posted November 6, 2008 Author Report Share Posted November 6, 2008 guys???? Quote Link to comment Share on other sites More sharing options...
