yamaha_rider619 Posted November 2, 2008 Report Share Posted November 2, 2008 i just replace the cylinders, pistons, carbs(with a set of used ones in good condition), and put individual k&ns on. This banshee started right up and ran just fine but only exhaust came out of one side. The engine sounded fine and ran good but there was no exhuast out the left side. Also the right side a good amount of white exhaust and the carburetor was leaking a lot of fuel from the overflow from the flowbowls. The carbs also look to be in sinc. Maybe the carbs just need cleaned? Can anyone help? Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted November 2, 2008 Report Share Posted November 2, 2008 the float in the carb is either stuck or not adjusted properly. youre gonna have to pull the right side carb off and check it. so theres nothing coming out of the left exhaust? Quote Link to comment Share on other sites More sharing options...
2001Stroker Posted November 2, 2008 Report Share Posted November 2, 2008 What he said. Plus you need to get them sync'd, fo sho. I pulled mine off, and somehow got them way outta sync, and it did the same thing. No exhaust out of one side. Sounded like both sides were running, but no smoke. When you put a load on it, it ran like shit on top end too. Sync'd them, and ran great. Got smoke out both sides. Quote Link to comment Share on other sites More sharing options...
yamaha_rider619 Posted November 2, 2008 Author Report Share Posted November 2, 2008 the float in the carb is either stuck or not adjusted properly. youre gonna have to pull the right side carb off and check it. so theres nothing coming out of the left exhaust? i could feel a very small amount of exhaust but could not see any smoke at all or hear the left side either. Quote Link to comment Share on other sites More sharing options...
05.Banshee.SE Posted November 2, 2008 Report Share Posted November 2, 2008 i could feel a very small amount of exhaust but could not see any smoke at all or hear the left side either. Sounds like the problem is in your carb. I've had the same exact problem...well, my left side was weak. Left carb slide was a bit off, and my throttle cable was f'ed up. 30 mins cleaning up carbs, and tuning it had the Shee running sweet again. Quote Link to comment Share on other sites More sharing options...
yamaha_rider619 Posted November 2, 2008 Author Report Share Posted November 2, 2008 thanks! i will clean them up and sync them this week and let you all know Quote Link to comment Share on other sites More sharing options...
yamaha_rider619 Posted November 3, 2008 Author Report Share Posted November 3, 2008 Turned out the left carburetor just needed a little cleaning and a jump start with some cleaning fluid, then it worked just fine. The part about the exhaust not coming out the left side was because the left carb was barley running and there was a cut in the exhaust clamp which let a lot of exhaust out. Quote Link to comment Share on other sites More sharing options...
