acfine Posted October 27, 2008 Report Share Posted October 27, 2008 Anyone know of a good place to buy new plug wires for my shee??? Thanks, Anthony Quote Link to comment Share on other sites More sharing options...
mdhc500 Posted October 27, 2008 Report Share Posted October 27, 2008 Anyone know of a good place to buy new plug wires for my shee??? Thanks, Anthony If you have a stock coil you will can just make your own. Just get some good quality 7mm or 8mm wire and some NGK 5K ohm caps... Easy and cheap for the most part. Quote Link to comment Share on other sites More sharing options...
acfine Posted October 27, 2008 Author Report Share Posted October 27, 2008 If you have a stock coil you will can just make your own. Just get some good quality 7mm or 8mm wire and some NGK 5K ohm caps... Easy and cheap for the most part. Thanks! Quote Link to comment Share on other sites More sharing options...
Troubledsol Posted October 27, 2008 Report Share Posted October 27, 2008 I used the coil wire that comes with MSD wires if you know anyone with MSD wires they may have a spare peice it worked great Quote Link to comment Share on other sites More sharing options...
87_shee Posted October 27, 2008 Report Share Posted October 27, 2008 How do you guys connect the new wires to the coil? Do the old ones just pull out and push in the new ones, or do you have to splice them? I didn't think you could change the wires on a stock coil. Quote Link to comment Share on other sites More sharing options...
Troubledsol Posted October 27, 2008 Report Share Posted October 27, 2008 My wires were bad when I got the shee there are small clips going around the wire at the coil take that off and pull Then I stripped off the end of the insulation and bent a piece over the end of the wire and pushed it into the hole with a little black rtv to seal it works great Quote Link to comment Share on other sites More sharing options...
acfine Posted October 28, 2008 Author Report Share Posted October 28, 2008 How do you guys connect the new wires to the coil? Do the old ones just pull out and push in the new ones, or do you have to splice them? I didn't think you could change the wires on a stock coil. That was my question as well. I looked last night and didn't see how the factory plugs could be disconnected from the stock coil. Thanks, Anthony Quote Link to comment Share on other sites More sharing options...
acfine Posted October 28, 2008 Author Report Share Posted October 28, 2008 Could my TORS system be doing this? Half the time I start my shee, and I rev it up, it acts as if the parking break is on, then I move the cable at the clutch lever, and the thing revs normally. What all is involved in removing this comepletely? Just disconnecting the plugs to the carbs, or is there more involved? Such as the wiring from the clutch handle going into the little TORS box? Thanks, Anthony Quote Link to comment Share on other sites More sharing options...
