Ton of Parts from 95-01
I listed all these parts in my other thread for the toomeys, They sold and i realized the title only said toomeys for sale and didnt see link to edit the title. Sorry for the repost.
Prices are + shipping unless posted shipped. Will deal if you buy a few things. I can accept paypal or money order whichever is easier for you. Have pics of some of it still have to get pics of some. All parts are in working useable condition unless stated, used w/ normal wear. All from 95 or newer quad. Most from the 97 or 01 . NE ohio near youngstown if close feel free to pick up.
- Engine cases w/ side covers normal chain slap damage to left no leaks, cracks $95
- Oem swingarm could use paint or pc bearings seemed good $25
- Oem gas tank w/ petcock and cap $20
- Kicker lever good splines $20 shipped
- Kick shaft w/ spring, gear, bushing Good splines $17 shipped
- Trans main & counter w/ all gears, c clips, bearings, sprocket nut... $100 shipped
- Complete clutch - basket, hub, plates, rod, springs etc. 1 spring bolt missing but i should have one for it, plates show wear but still good life left $50 shipped
-oem steering stem w/ 7/8 barclamps, and mounting clamp/bushings $30
- Rear wheel hubs good splines $40 shipped
- Front Brakes complete master/lever, lines, and calipers w/ 60-70% pads $65 shipped
- oem Spindles w/ guards $30 shipped
- Oem axle cosmetic wear, good splines and threads $30
- Rear brake m/c w/ lever, resivior and lines $35 shipped
- Pipe hangers $17 shipped
- Front fender brackets $17 shipped
- Front hubs w/ rotors good shape, straight rotors, bearings feel good. $50 shipped
- Radiator no leaks w/ overflow bottle and hoses $20
- wire harness cpl cut wires but ends still there to work w/ headlight switch housing switch is missing a peice inside but rest in good shape no cdi or coil $35 shipped
- Shift mechanisms shift drum/forks, star, shift shaft and shifter lever etc $30 shipped
- F & R sprockets w/ sprocket hub 41t and 13t good shape $20 shipped
- Engine mounts $17 shipped
- Seat needs recover (hole) and foam repair or replace good pan and latch $15
- Front shocks yellow springs need cpl bushings $20
- Rear shock linkages $17 shipped
- Stock axle minor bend on right (only noticed down the road in high speed) $10
- Stator w/ adjutable timing plate (meter tested good) quad bought needing rebuild then torn down so never tested. Red wire cut and was inline crimped in place. end still intace could be soldered $55 shipped
- Seat Gray cover nice shape w/ latch $40
- Cylinders 64mm stock porting untouched, left has some scoring nothing major. right had over 100psi left around 60psi should be bored but a hone might do. Pistons come with $175
- Full chassis skid w/ all bolts and clamps $50
- Ac grab bar one taillight tab has jbweld, not cracked all the way through just the tailight bracket the rest is in good shape $15
-Ac front bumper polished bottom pushed in a little from nosedive mounts up good and hard to tell on quad. $15
- Mikuni Stock carbs w/ tors and cables $60 shipped
- White front shocks w/ bushings $20
- Pro Armor Nerfs polished w/ black nets (nets fit but extra peices towards frame taped up) straight $50
- Spindles $30 shipped
- Clutch lever/perch w/ cable and ebrake cable $20 shipped
- Front hubs w/ Rotors straight no grooves need bearings $45 shipped
- Stock pipes and silencers sanded and painted high temp black $50
- Stock metal footwells $10
- A arms silver straight, normal paint wear on lowers good balljoints and boots come w/ tie rods $90
- Radiator w/ overflow $20
- Wire harness no components good shape $25 shipped
- Rear Brake Caliper w/ mc lever, brake line and resi, good pads if mem serves $60 shipped
- Stock airbox w/ lid and foam filter $30
- Headlight/run switch $25 shipped
- Stock head very minor buildup on one dome other one mint $25 shipped
- Thumb throttle $25 shipped
- Tie rods w/ good ends and boots $15
- Stock footpegs worn but still grab $20 shipped
- Oem rear wheels straight normal wear on lips $45
- Oem front wheels straight w/ wear on lips $45 ($80 for all 4)
- Like new kenda front tires 22/7/10 (short 22) $30
- Oem clutch perch/lever w/clutch cable $17 shipped
- Carb caps w/ tors good wiring $15 shipped
- ignition switch w/ key $25 shipped
Few things you guys can have free if interested just pay shipping
- stock airbox cut out (completely open) w/ uni filter
- white rear shock spring stock
- stock crank needing a rod bearing
- pink front shocks ( 1 is bent)
Have white full fender, and white race cut plastics, 01 frame w/ title 2 dents in front from bumper straight, 97 frame bill of sale. Local only on the frames and plastic sorry.
also have quite a few sets of misc 7/8th handle bars $5 a peice have one peice design and crossbar type.
If you'd like to see pics of anything just ask. Ill post up more when i get time also.
Thats alotta stough!
Ill have to box up the cases and check shipping to your zip to get a better quote. I guesstimated the weight and size and looks like around $30-40 w/ ups tops probably a little less.
You can have the 3 for $150 + whatever actual shipping is. Ill get the cases in a box and send you a msg w/ shipping price.
thanks
Stator w/ adjustable plate sold
set of engine cases and thumb throttle sold also but i have 1 more set of cases and 2 throttles still.
- Stator w/ adjutable timing plate (meter tested good) quad bought needing rebuild then torn down so never tested. Red wire cut and was inline crimped in place. end still intace could be soldered $55 shipped SOLD
