Parting out 19 Banshees - what do you need?
Minkia38
Hey there,
Do you have any black plastics?
Also need aftermarket pipes for a good deal.
thanks
17 Banshees on the chopping block
Parting them all out.
Let me know what parts you need, or click on my signature to see my ebay auctions
(Red Fullbores not for sale)
This picture was from April 21st, but these are all gone (except the 4 strokes and my red fullbore):
  • 1 month later...
Located in Northern Macomb, 48042
Engine1,000.00
Intake boots/Boost25.00
Reeds and cages25.00
Carbs and cable110.00
Airbox (or air filter)40-70.00
Kicker50.00
Gas tank$30.00
Pipes oem25.00
Frame components
Frame300.00
Steering stem25.00
A-arms / J-arms300.00
Swingarm30.00
Axle100.00
Bearing carrier50.00
Footpegs10.00
Nerf Bars / Heel guards40.00
Rear Hubs45.00
Rear Sprocket & Hub25.00
Rear Rotor disc & Hub25.00
Dogbone10.00
Rear Grab Bar15.00
Front Bumper Pushbar20.00
Shifter10.00
Skid Plate20.00
Plastic
Front & rear Fenders200.00
Grill + Radiator Plastic30.00
Gas Tank Wrap Plastic30.00
Seat w/ latch50.00
Fender brackets10.00
Electrical
CDI Box50.00
Wiring harness / Loom35.00
Coil20.00
Headlights60.00
on/off switch25.00
Key w/ plastic housing35.00
Taillight25.00
Misc
Rear brake setup100.00
Bolt set25.00
Rear Shock80.00
Front shocks80.00
Front tires & rims100.00
Rear tires and rims120.00
Handlebars & grips10.00
Clutch lever / perch10.00
Thumb Throttle lever30.00
Radiator & Reservoir30.00
Front brake lines10.00
Front brake lever/rezzy25.00
Motor Mounts20.00
cylinders 300
crank 150
shift drum 10
gears/tranny 150
cases 200
clutch cover 30
stator cover 15
stator + plate 75
bolts 20
head 25
flywheel 75
  • 1 month later...
