What compression are you running?
grpark20
Just curious to see what every one with the 4 mil long rod and port work to match is running for compression, or what you are trying to shoot for? Basically what would you consider the optimum compression when you factor in the expense to ride with your octane requirement. I know everyone will be different for various reasons and conditioins you built your shee for (dune, drag, trail). If you could add your octane, dome size, and timing if any will help too. Thanks.
What kind of fuel are you trying to run? I have set them up for between 145 and 185 depending on application and fuel intended
I'd like to be able to run 93 pump gas...but if the gains for higher compression meaning running race fuel are worth it, then I'll go that route. Just want to here whats making everyone happy.
Well, like I said...It also depends on application. For example, I like to set trail or Mx motors at 180 if the customers budget allows race fuel. Those engines will benefit more from the added compression=more low end grunt. But I like to set my duners and drag motors up with less compression so they will rev out easier. I would go 145-150 for pump gas. I like to set up engines for about 165 to run alcohol. A nice compromise seems to be about 160-165 on 100 octane.
I will also add that if you're going to set yourself up to have to run race fuel, just skip it and go to methanol.
Yes there are all the negatives of which I'm well aware but the gains in power and running cool are worth it for me.
Point well taken.....I was running 100LL AV Gas on the old set up I had. Never checked the compression but was widing @ sea level with 20cc domes. I could ride the trails and logging roads for 6 hours and burn 3/4 of a tank. Going to be a lot different with new set up.
