need advice
twillz08
I am new to the quad world and was looking at buying a quad but i really did not want a 4 stroke i grew up riding 2 stroke bikes i just love the powerband. I did some reading about the banshee and tons of people say it sucks for trails, is this true or could it be there just not use to the 2 stoke style i mean i could ride trails all day on my CR125 and it was great. also how long do they last before they need to be rebuilt if they are cared for? second would it be worth buying this banshee-- one more thing it has a +6 Swinger how will this affect the handling and Ability to ride on trails, how hard would it be to go back to a stock swing arm. the Mods are as followed
Asking 3k
CHASSIS-
Stretched swingarm 6"
Widened 4" with A-arms and axle
"Armadillo" chromoly A-arms
WORKS remote res shocks
Lone star x-caliber adjustable rear axle
Braided brake lines
Swing-arm and frame skid plates
ITP Baja wheels
Holeshot mx tires
DG nerfs, bumper and grab bar
MSR bars
new clutch cable
new front wheel bearings
CEET brand seat cover
FULL BORE racing plastic
Pro-design teather
ENGINE- the motor is on its second tank of fuel at the moment running klotz oil
Wiseco hot rods crank and rods
Wiseco pro-lite pistons and rings
light port work
pro-design cool head w/ 21 cc domes
V-force reeds
reed spacers
lone star 2 into 1 carb base
PKW carb
KN filter
Adjustable timing plate
FMF fatty pipes (no dents)
New trans main shaft with all new clutch components and heavy duty barnett clutch with roller throw out upgrade.
Edited by twillz08
If you shortened it up a bit, it would be fine for trails. The +6 is a little long for tighter trails, but with the engine work listed you could easily get away with a +2 or even a stock swingam. The FMF's are a great trail pipe. A lot of how it performs will depend on how the portwork was done and if it was matched to the pipes. As far as reliability, again that will depend largely on the work done in the cylinders (if the builder chamfered the ports correctly, the exhuast port roof is rounded, the exhaust ports are not too wide and the piston-cylinder clearance is good) and how well it is or has been maintained. I've seen banshees run reliably for years and other run good for a day. Other than the swinger, the rest of the mods are pretty much trail mods.
And yes it was on the Mn Craigslist. i met them in forest lake do you think it may have been sold and they are trying to resell?
also forgot to Add it was bored .20 over i was told only about 5 tanks on the new rebuild. i was planning on bringing a compression gauge with me when i go to inspect whats a good number?. anything else i could look for with out tearing it apart?
Edited by twillz08
