278 Posted October 19, 2008 Report Share Posted October 19, 2008 OK so I went to an auto parts store to get what I needed to put my motor back together (assembly lube, thread lock, silicone gasket maker for the case halves) and when I asked them about o-ring lube they said they had never heard of it and I explained it and they said new o-rings shouldnt need it, so my question is do you need o-ring lube to install a cool head and if so is there something else you can use? Quote Link to comment Share on other sites More sharing options...
BellicoseBanshee Posted October 19, 2008 Report Share Posted October 19, 2008 Do you need o-ring lube to install a cool head and if so is there something else you can use? Use a thin layer of grease to hold the o-rings in place during installation... Quote Link to comment Share on other sites More sharing options...
Wildcardracing Posted October 19, 2008 Report Share Posted October 19, 2008 You can use grease or vasoline to hold the o-rings in the grooves, but it's not absolutely neccisary. Only purpose it serves is to keep your o-rings from falling out when the head is being placed on the cylinders. As far as the silicone goes, I wouldn't recommend using regular RTV silicone. You need to use a semi-drying sealant such as three-bond 1197 or equivelant. Quote Link to comment Share on other sites More sharing options...
