Jetting question once again
bansheesa
Sorry about this question again.
This is what I have: 20 overbore with Wiseco Pro Light's, VForce 3 reeds and cages, +4 timing (Pro Design), Cool Head (Pro Design) 22cc, FMF fatties with powercore 2, Pro Design foam filter (Yellow with red outfilter) and adaptor, open airbox with box outerware. I am at sea level and average of 80 F. Jetting at the mo: 280 main, 25 idle, dynojet needle at 4 down. Mixing at 32:1 (belray synthetic).
I know with the mods, I am running to lean. Please put me close to if not spot on.
Thanks
280 seems a bit lean for those mods.Its better to start rich and work your way down.Try starting at 320 on the mains.
You need to go up 2 on the pilots for the pipes and 0-2 for the reeds.
Dont forget to adjust your air screws.
How does shee ride?
Does shee act funny?if so at what point in the throttle?
Thanks, will look into it. Shee sputters a bit before power band. Kind of like a carb battling to clear. Battles to start if not hot. Here in South Africa, we do not have a nice stretch to do a plug chop. So it is a bit difficult. Top end in 4th or so seems fine. But I know that shee is running lean. I will also check with the rev and airscrew test to see on low end.
Also would like to know the better tires to run on the shee for cross-country and out rides (jungle like with lots of ups and downs and dirt ranging from loose to compacted)
Thanks
