right now i currently am running the stock carbs..
mods are
t5's
cool head w/18cc domes
timing plate at +4
ported cyl
everything else is stock..
i figured while i was doing all this work i would see if i should upgrade the carbs too.. dont plan on doing much more.. so will the stock carbs work fine with this setup.. it seems to run and ride good.. but this is my first banshee!
I'm sure the stock carbs will work fine.You may be surprised from unleashed power in bigger carbs.I'm not sure but I'll be able to tell you after my 1st trip to the dunes. :biggrin: You do have ported jugs!
Yes, i would recommend new carbs, stocks are ok but get some pwk's and they will wake it up.
