lt1bird Posted September 20, 2008 Report Share Posted September 20, 2008 What tool is needed to remove the clutch bolt and where can i get one? Its kicking my butt and im tired of playing with it... Thanks! Quote Link to comment Share on other sites More sharing options...
spurdy Posted September 20, 2008 Report Share Posted September 20, 2008 What tool is needed to remove the clutch bolt and where can i get one? Its kicking my butt and im tired of playing with it... Thanks! They make a claw you can hold the basket with. Don't know where you can get one though, sorry. I just hold it with my hand and use an impact gun. Worked fine for me everytime. SP Quote Link to comment Share on other sites More sharing options...
lt1bird Posted September 20, 2008 Author Report Share Posted September 20, 2008 Hmmmm maybe ill get an impact gun.... any one know where to get the correct tool? Quote Link to comment Share on other sites More sharing options...
lt1bird Posted September 20, 2008 Author Report Share Posted September 20, 2008 engine is on the bench......did you do that in the frame with chain on? Quote Link to comment Share on other sites More sharing options...
shee4speed Posted September 20, 2008 Report Share Posted September 20, 2008 impact should remove that dude.Motion Pro makes the clutch holing tool though.Check it out here Quote Link to comment Share on other sites More sharing options...
SAVAGE420 Posted September 20, 2008 Report Share Posted September 20, 2008 What tool is needed to remove the clutch bolt and where can i get one? Its kicking my butt and im tired of playing with it... Thanks! A lil trick is to put a penny in between the gears as it will hold the basket from turning and is soft enough to not wreck the gears, worked every time. The socket needed is 32mm :thumbsup: Quote Link to comment Share on other sites More sharing options...
bansheejoel Posted September 20, 2008 Report Share Posted September 20, 2008 i put a rag in between my gear and that worked awesome. Heard the penny trick works well to Quote Link to comment Share on other sites More sharing options...
lt1bird Posted September 20, 2008 Author Report Share Posted September 20, 2008 Between the gears? There does not seem to be any gears to put the penny into.... The inner clutch basket just spins and the only gear I can find that turns is the main chain sproket.... gonna get a impact gun and try that... Ill buy the holding tool and have it for assembly! Thanks! Quote Link to comment Share on other sites More sharing options...
lt1bird Posted September 20, 2008 Author Report Share Posted September 20, 2008 Got a working impact gun and the dam nut came right off....thanks all! Now the main drive gear nut will not come off......even with the impact gun all the way up and holding the flywheel tight. It does come off CCW correct? Any hints? maybe heat it with a torch??? Quote Link to comment Share on other sites More sharing options...
