Boost bottles for bearing carrier
pcduc64
I will have to look and see if the jets are still in them. They should still be. I have not parted them out.
And Yes, they were running.
I put a single carb on both one of my banshees.
I also have a keihin flat slide 38mm carb that I took off of my 96, it was running when I took it off. The reason I took it off was to put a trinity set up so I could use my airboxes correctly.
I have an airstyker 38mm that the idle stop broke. The carb is still in working condition other then that.
Edited by pcduc64
