gclark63 Posted September 21, 2008 Author Report Share Posted September 21, 2008 mine did the same thing when i melted my harness to one of my damn silencers. New wires in harness. They all check out fine? Quote Link to comment Share on other sites More sharing options...
gclark63 Posted September 21, 2008 Author Report Share Posted September 21, 2008 Every thing is checking out, could my jetting be the problem? 340mains, 25 pilot the jet by the air screw is a 25 Quote Link to comment Share on other sites More sharing options...
pr0blumz Posted September 21, 2008 Report Share Posted September 21, 2008 You don't have the plug wires switched by any chance do you? Your timing you should be atleast 0 Quote Link to comment Share on other sites More sharing options...
FireHead Posted September 21, 2008 Report Share Posted September 21, 2008 New wires in harness. They all check out fine? Have you actually sat there and connected your DVOM to the end of each wires going to your coil, stator, CDI, etc. to make sure that they are all below 1.5 ohms? If they are higher than that, then the wiring is bad, even if it looks fine. You do not have a jetting problem. Quote Link to comment Share on other sites More sharing options...
FireHead Posted September 21, 2008 Report Share Posted September 21, 2008 You don't have the plug wires switched by any chance do you? Are you kidding? WTF............... as long as the plug wires are on the spark plugs and are functioning, then it doesn't matter which cylinder they are on. Quote Link to comment Share on other sites More sharing options...
hylander88 Posted September 21, 2008 Report Share Posted September 21, 2008 New wires in harness. They all check out fine? dumb question but with the new wire harness did you re-hook up the key switch or did you jump it?? or nothing??? Quote Link to comment Share on other sites More sharing options...
gclark63 Posted September 22, 2008 Author Report Share Posted September 22, 2008 dumb question but with the new wire harness did you re-hook up the key switch or did you jump it?? or nothing??? jumped the key switch, tors removed and park brake removed. Quote Link to comment Share on other sites More sharing options...
gclark63 Posted September 22, 2008 Author Report Share Posted September 22, 2008 Have you actually sat there and connected your DVOM to the end of each wires going to your coil, stator, CDI, etc. to make sure that they are all below 1.5 ohms? If they are higher than that, then the wiring is bad, even if it looks fine. You do not have a jetting problem. yes, just finnished and they all check out good.???? Quote Link to comment Share on other sites More sharing options...
FireHead Posted September 22, 2008 Report Share Posted September 22, 2008 yes, just finnished and they all check out good.???? Did you ever do a leak down test on this thing? Quote Link to comment Share on other sites More sharing options...
1996dragshee Posted September 22, 2008 Report Share Posted September 22, 2008 damn man.i probably would have burned it down to the ground by the 3rd page of this topic! good luck man Quote Link to comment Share on other sites More sharing options...
gclark63 Posted September 22, 2008 Author Report Share Posted September 22, 2008 damn man.i probably would have burned it down to the ground by the 3rd page of this topic! good luck man the thought has crossed my mind. Quote Link to comment Share on other sites More sharing options...
gclark63 Posted September 22, 2008 Author Report Share Posted September 22, 2008 Did you ever do a leak down test on this thing? explain leakdown? Have done compression test. Quote Link to comment Share on other sites More sharing options...
FireHead Posted September 22, 2008 Report Share Posted September 22, 2008 explain leakdown? Have done compression test. A compression test is only half of the battle on reed valve two stroke engine. Read this: http://www.bansheehq.com/forums/index.php?...ak+Down+Testing :geek: Quote Link to comment Share on other sites More sharing options...
BenBB Posted September 22, 2008 Report Share Posted September 22, 2008 Sounds like the flywheel is the only electrical component you haven't replaced...if it was mine I'd find one and at least pull the pipes to see if the pistons look like they aren't moving opposite each other (your crank could be out of phase as you suspect)... Quote Link to comment Share on other sites More sharing options...
speed-racer Posted September 22, 2008 Report Share Posted September 22, 2008 Try running a ground strap from the frame to the engine. If the engine is at the same potential as the coil, it will not fire. You can check for spark by grounding to the cylinder head and then to the frame.....there should be spark at both. Quote Link to comment Share on other sites More sharing options...
