pr0blumz Posted September 15, 2008 Report Share Posted September 15, 2008 If you were Rich you could have "slightly" adjusted your pre-mix... Like if you were running 32:1 youcould have tried 40:1 to help with it a bit... Glad you had fun and didnt ruin anything. You mean run more oil and less gas to lean it out some, if that's what you were referring to. Quote Link to comment Share on other sites More sharing options...
LS1Inferno Posted September 15, 2008 Report Share Posted September 15, 2008 You mean run more oil and less gas to lean it out some, if that's what you were referring to. no 40:1 is less oil but don't do that premenatly its just a quick trip thing to avoid for ebing a lil rich. fix it right will be better Quote Link to comment Share on other sites More sharing options...
mdhc500 Posted September 16, 2008 Report Share Posted September 16, 2008 no 40:1 is less oil but don't do that premenatly its just a quick trip thing to avoid for ebing a lil rich. fix it right will be better By all means fix it right, but in a pinch leaning out your mix would do the trick... Quote Link to comment Share on other sites More sharing options...
Dark Ranger Posted September 17, 2008 Report Share Posted September 17, 2008 If you are going from 32:1 to 40:1 you are going from 32 parts gas, 1 part oil to 40 parts gas, 1 part oil. That means more gas, which actually makes you richer. Remember, it's the fuel/air mixture you are jetting for not oil/air. Quote Link to comment Share on other sites More sharing options...
pr0blumz Posted September 18, 2008 Report Share Posted September 18, 2008 If you are going from 32:1 to 40:1 you are going from 32 parts gas, 1 part oil to 40 parts gas, 1 part oil. That means more gas, which actually makes you richer. Remember, it's the fuel/air mixture you are jetting for not oil/air. My point exactly. Quote Link to comment Share on other sites More sharing options...
Meat Posted September 18, 2008 Report Share Posted September 18, 2008 If you are going from 32:1 to 40:1 you are going from 32 parts gas, 1 part oil to 40 parts gas, 1 part oil. That means more gas, which actually makes you richer. Remember, it's the fuel/air mixture you are jetting for not oil/air. right on. good post dark ranger Quote Link to comment Share on other sites More sharing options...
