nvrhapy Posted September 13, 2008 Report Share Posted September 13, 2008 hey guys i have a unique setup and hoping u can help i have a lifted golf cart with banshee lower a arms and front shocks my problem is the suspension is very stiff not much travel at all, i have adjusted the shocks to the softest setting already and not much has changed. can any one tell me what the spring rate on these shocks are? or any opinions on these shocks or my setup, any help would be great thanks here is some pics Quote Link to comment Share on other sites More sharing options...
bbcmudtruck Posted September 13, 2008 Report Share Posted September 13, 2008 Looks pretty cool. Try a different pair of shocks off of a smaller four wheeler. I know the 300ex shocks are a hell of alot softer, but they also have less travel and are about 2" shorter. Quote Link to comment Share on other sites More sharing options...
lilmegill727 Posted September 13, 2008 Report Share Posted September 13, 2008 that looks cool. try blaster shocks Quote Link to comment Share on other sites More sharing options...
hercalmighty Posted September 13, 2008 Report Share Posted September 13, 2008 It looks like you have the shocks on the hardest setting in the pics. Did you make this set up yourself? Quote Link to comment Share on other sites More sharing options...
Michael Jackson Posted September 13, 2008 Report Share Posted September 13, 2008 yea those shocks are on the stiffest setting in the pics either way, they suck, bad and blaster shocks are even worse Quote Link to comment Share on other sites More sharing options...
ban99 Posted September 13, 2008 Report Share Posted September 13, 2008 hard to tell exactly off of a picture but it looks as though the axle is ridged with no piveting spindals which in my opinion would be the problem. With the current set-up the only way to compress the suspension is to force the tires to slide outward acros the pavement. If you want to do it right get a used set of banshee or blaster a-arms off e-bay (uppers as well as lowers)plus the spindals and hubs. Quote Link to comment Share on other sites More sharing options...
nvrhapy Posted September 13, 2008 Author Report Share Posted September 13, 2008 i did not do this setup i bought the cart with it setup this way, im just trying to improve on it. wasnt sure if just switching out the springs would work to soften it up and to give it more travel or if doing a double a arm set up would solve the problem. so these shocks are garbage? i did adjust the shocks to the softest setting this picture was taken before the change though. Quote Link to comment Share on other sites More sharing options...
atvfreestylekid Posted September 14, 2008 Report Share Posted September 14, 2008 If you could get some banshee arms or somthing with the mounting hole closer to the middle of the arm, It will lift it as well as make it ride smoother. Quote Link to comment Share on other sites More sharing options...
nvrhapy Posted September 14, 2008 Author Report Share Posted September 14, 2008 hey freestyle kid what exactly do you mean? i posted this same question on a couple other forums and got a somewhat similiar reply about moving the shock location inward more i tried relocating the upper mount to see if it helped and didnt notice much difference but didnt move the lower shock mount in closer. here is a pic of the upper mount moved in closer should i leave it and move the lower one in more is this what you mean Quote Link to comment Share on other sites More sharing options...
nvrhapy Posted September 14, 2008 Author Report Share Posted September 14, 2008 also what is the travel on these banshee shocks? Quote Link to comment Share on other sites More sharing options...
hercalmighty Posted September 15, 2008 Report Share Posted September 15, 2008 You need to move the lower mounts in so that 1. you get more leverage from the arm working on the sock 2. that will give you more travel from the arms Quote Link to comment Share on other sites More sharing options...
nvrhapy Posted September 16, 2008 Author Report Share Posted September 16, 2008 should i keep a slight angle to teh shock or have it so its straight up and down Quote Link to comment Share on other sites More sharing options...
