No Sixth Gear?
dsmrx7
My 96' Banshee doesn't have a 6th gear. It ran real good and shifted smooth all the way to 5th gear and then won't go into the "6th gear." Did some Banshee's not come with a 6th gear? :huh:
No, all Banshees have 6 gears.
Did you pull the clutch cover and check the shift start and the claw? I'd check that first.
If that looks good then it sounds like a problem inside the cases. Could be something with the shifting cam, or something with the 6th gear or the gear that meshes with the 6th gear.
If it were me, I'd split the cases and have a look before riding it anymore. If there is a broken piece floating around in there you could likely do more damage internally.
SP
Edited by spurdy
Did you count one down for first then 5 up and forget the one down = 6 :yelrotflmao:
I know someone who did that once, not naming names either :whistling:
Nope, Im pretty sure its 1 down and 4 up. My brother confirmed it too. Gears look really good, no chips, no shavings, nothing. Maybe I got a Special Edition Banshee with a 5-speed :biggrin: :huh: .
