OKCterror Posted September 7, 2008 Report Share Posted September 7, 2008 Got a shaved head today from jrod who got it off banshee dans old bike. Scored for free since jrod is the man. Thanks again, any time you need a push on that car of yours just ask.lol. Anyways do shaved heads add any power? Will it cause any damage on my motor(specs listed below) if i slap it on? Help me out. I wanna hook this thing up asap.-Dan Quote Link to comment Share on other sites More sharing options...
OKCterror Posted September 7, 2008 Author Report Share Posted September 7, 2008 no idea, pmed the guy who had it milled. waiting on him. looks damn clean though. Gonna add the new air filter, new plugs, ice coolant, and the jump timing +4 and she what happens. Quote Link to comment Share on other sites More sharing options...
GrMeyer Posted September 7, 2008 Report Share Posted September 7, 2008 no idea, pmed the guy who had it milled. waiting on him. looks damn clean though. Gonna add the new air filter, new plugs, ice coolant, and the jump timing +4 and she what happens. Run 100 oct just to be safe with the start up Quote Link to comment Share on other sites More sharing options...
OKCterror Posted September 7, 2008 Author Report Share Posted September 7, 2008 where can i get 100+ Quote Link to comment Share on other sites More sharing options...
GleasmJA Posted September 7, 2008 Report Share Posted September 7, 2008 i got my head shaved a while back from a member on here. He went 20 thou and i still run pump gas, premium but who doesn't. That with timing advance and haven't had a problem with it yet. Quote Link to comment Share on other sites More sharing options...
OKCterror Posted September 7, 2008 Author Report Share Posted September 7, 2008 did it add any power? powerband? Quote Link to comment Share on other sites More sharing options...
GleasmJA Posted September 7, 2008 Report Share Posted September 7, 2008 I can't tell if it helped alone... i did carbs, the head, fly wheel and freshened everything up all at the same time. But it won't hurt anything. Just check your compression and see how high it is.... anything real high and you may have to run some race gas mixed. Quote Link to comment Share on other sites More sharing options...
OKCterror Posted September 7, 2008 Author Report Share Posted September 7, 2008 how do i do a comp check Quote Link to comment Share on other sites More sharing options...
shee rips Posted September 7, 2008 Report Share Posted September 7, 2008 i got .020 taken off mine, i freshened up the top end at the same time, but it was a good power gain i did the math on it, and i think it was .020 off is the equivalent of going 1 cc smaller. check the squish once you get it on. my squish is about .035 with .020 taken off the head. just so you have an idea where your at, unless its been rechambered, then this wont really work for comparison Quote Link to comment Share on other sites More sharing options...
OKCterror Posted September 7, 2008 Author Report Share Posted September 7, 2008 whats squish??? Quote Link to comment Share on other sites More sharing options...
shee rips Posted September 8, 2008 Report Share Posted September 8, 2008 its the clearance between the piston and the head. to measure it,take a peice of solder and bend it into an L shape. and insert through the spark plug hole( dont drop it). put it so its in line with the piston pin, and all the way to the cylinder wall, and slowly turn over the engine with the kick starter. it will s1quish the solder. then you measure the squished part with a micrometer. Quote Link to comment Share on other sites More sharing options...
OKCterror Posted September 8, 2008 Author Report Share Posted September 8, 2008 ok now how do i do a comp check Quote Link to comment Share on other sites More sharing options...
05.Banshee.SE Posted September 8, 2008 Report Share Posted September 8, 2008 With a compression gauge. You can find one at Napa, or a local mechanic can probably do it for cheap. Buy one, you'll be using it enough for the cost to be worth it. Get the bike warm, take a plug out, plug in the gauge, kick it over a few times WOT until the gauge stops rising. (6-7 kicks is normal I believe?) Repeat for the other side. There should be no difference, or very little in lbs. between cylinders. If they are off by more, something is wrong. You should comp check it before and after you install it. Quote Link to comment Share on other sites More sharing options...
05.Banshee.SE Posted September 8, 2008 Report Share Posted September 8, 2008 its the clearance between the piston and the head. to measure it,take a peice of solder and bend it into an L shape. and insert through the spark plug hole( dont drop it). put it so its in line with the piston pin, and all the way to the cylinder wall, and slowly turn over the engine with the kick starter. it will s1quish the solder. then you measure the squished part with a micrometer. Check your PMs man!! I've been looking for the sticker in your sig forever. Quote Link to comment Share on other sites More sharing options...
OKCterror Posted September 8, 2008 Author Report Share Posted September 8, 2008 is wot=wide open throttle? Quote Link to comment Share on other sites More sharing options...
