jrod Posted September 6, 2008 Report Share Posted September 6, 2008 Ok i just completed my first rebuild. I have 40 over wiesco's dune/Trail A&S port work, Timing plate at +4, Stock carbs, K&N pods, either FMF fattys or TR6 i have both, coolhead with 20cc domes. I just put everything together last night started up 3rd kick. But i know my jetting is way off. Now i have never jetted one before. My question is, by changing carbs will it help my alot or will stock carbs be ok for my setup? And if so what carb setup? Single trinity? 30's 35's? And what jets would you guys run in the stocks? And will it be the same in the bigger carbs? I really want to get the most out of this setup, so please lend your knowledge. Thanks, Jared oh and if anyone is local to okc could you help? Quote Link to comment Share on other sites More sharing options...
LiftdT4R Posted September 6, 2008 Report Share Posted September 6, 2008 On the jetting, whoever did the port work will honestly know best. Every port job is a little diffrent, but if you call up the builder he should be able to get you in the ballpark. As for the carbs. Stockers should work just fine on that setup. Although, an aftermarket carb/carbs will definately give you some more power. As far as choices, search around, and read some reviews on the different setups. A single may or may not be the right choice for you depending on what you do, or how you want the bike to ride. Quote Link to comment Share on other sites More sharing options...
jrod Posted September 6, 2008 Author Report Share Posted September 6, 2008 On the jetting, whoever did the port work will honestly know best. Every port job is a little diffrent, but if you call up the builder he should be able to get you in the ballpark. As for the carbs. Stockers should work just fine on that setup. Although, an aftermarket carb/carbs will definately give you some more power. As far as choices, search around, and read some reviews on the different setups. A single may or may not be the right choice for you depending on what you do, or how you want the bike to ride. thanks for the info, i am bidding on a singel setup on ebay right now. Hopefully i i will win. Quote Link to comment Share on other sites More sharing options...
LiftdT4R Posted September 6, 2008 Report Share Posted September 6, 2008 thanks for the info, i am bidding on a singel setup on ebay right now. Hopefully i i will win. What kind of riding do you have out in Oklahoma? Seems like mostly dunes, although I dont really know. Most of the guys using 2 into 1s are running out here on the east coast, and mostly in trails. Quote Link to comment Share on other sites More sharing options...
jrod Posted September 7, 2008 Author Report Share Posted September 7, 2008 What kind of riding do you have out in Oklahoma? Seems like mostly dunes, although I dont really know. Most of the guys using 2 into 1s are running out here on the east coast, and mostly in trails. I have never been to the dunes on my bike.LOL I mostly ride trails and farm land. Quote Link to comment Share on other sites More sharing options...
