themudgician Posted September 6, 2008 Report Share Posted September 6, 2008 i recently bought this banshee i was told it just had a clutch put in it. when im rippin on it i cant up shift very easy in any gear but if i let out of it i can get it to shift. any help would be awsome Quote Link to comment Share on other sites More sharing options...
brugal Posted September 6, 2008 Report Share Posted September 6, 2008 That sounds like a transmission problem. Quote Link to comment Share on other sites More sharing options...
OKCterror Posted September 6, 2008 Report Share Posted September 6, 2008 maybe you basket is engaging and causing pressure to be on your gears. My basket does it sometimes and its a billet Quote Link to comment Share on other sites More sharing options...
Onesickcrewcab Posted September 6, 2008 Report Share Posted September 6, 2008 Sounds like you need to adjust the clutch. Quote Link to comment Share on other sites More sharing options...
themudgician Posted September 6, 2008 Author Report Share Posted September 6, 2008 Sounds like you need to adjust the clutch. ok i just pulled the clutch cover off and the center bolt and nut are loose, and the clutch basket turns1/4 to 3/8 of a inch when the gear behind it stays still. help help i have no manual too look at and want to ride. Quote Link to comment Share on other sites More sharing options...
themudgician Posted September 6, 2008 Author Report Share Posted September 6, 2008 ok i just pulled the clutch cover off and the center bolt and nut are loose, and the clutch basket turns1/4 to 3/8 of a inch when the gear behind it stays still. help help i have no manual too look at and want to ride. im also pretty sure it a after market basket just seen a pic of a stock one . and mine looks alot different with long sloted holes in the fingers Quote Link to comment Share on other sites More sharing options...
themudgician Posted September 6, 2008 Author Report Share Posted September 6, 2008 im also pretty sure it a after market basket just seen a pic of a stock one . and mine looks alot different with long sloted holes in the fingersit is aftermarket there are little round black bushings on the back under the rear cover that are wore out. where can i get replacements. also i noticed someone ground dowwn all the points on the shifter star down to the pins exept the neutral. could that be some of the problem. Quote Link to comment Share on other sites More sharing options...
KEVSWS6 Posted September 6, 2008 Report Share Posted September 6, 2008 You shift star has been moded. That helps a lot for shifting. Replace your bushings on the basket. I found if you replace your clutch cable and handle with a nice aftermarket one it helps. Also make sure your clutch is adjusted corectly. Quote Link to comment Share on other sites More sharing options...
shanYE west Posted September 6, 2008 Report Share Posted September 6, 2008 Hinson and UPP sell cushions for the basket. Quote Link to comment Share on other sites More sharing options...
ohiobanshee Posted September 6, 2008 Report Share Posted September 6, 2008 Also make sure your shift shaft is adjusted properly. Quote Link to comment Share on other sites More sharing options...
themudgician Posted September 6, 2008 Author Report Share Posted September 6, 2008 Also make sure your shift shaft is adjusted properly. how do you adjust the shift shaft Quote Link to comment Share on other sites More sharing options...
themudgician Posted September 7, 2008 Author Report Share Posted September 7, 2008 how do you adjust the shift shaft could any of these things be causing a hard to shift at wot. or do i need to dig deeper Quote Link to comment Share on other sites More sharing options...
themudgician Posted September 7, 2008 Author Report Share Posted September 7, 2008 could any of these things be causing a hard to shift at wot. or do i need to dig deeperis it normal for the clutch basket cushions to be 2 different sizes,mine are about 1/4 difference in size. 1 big one and one little one in each slot. should the end of the shifter shaft be sloppy, the springed peice that moves the pins to shift. it hard to jugde a even gap to set it correctly. because of the slop prob about a 1/16 or so. any help guys would be great. Quote Link to comment Share on other sites More sharing options...
KEVSWS6 Posted September 7, 2008 Report Share Posted September 7, 2008 Cushions should not be different sizes. Not sure I'm understanding the slop issue? The claw that grabs the dowel like pins to shift is sloppy? Its just a little tension spring that holds it. It should move with very Little tension on it. Quote Link to comment Share on other sites More sharing options...
themudgician Posted September 7, 2008 Author Report Share Posted September 7, 2008 Cushions should not be different sizes. Not sure I'm understanding the slop issue? The claw that grabs the dowel like pins to shift is sloppy? Its just a little tension spring that holds it. It should move with very Little tension on it. where the claw swivels up and down on the shifter shaft plate is loose and sloppy Quote Link to comment Share on other sites More sharing options...
