Click help
OKCterror
I have a stock rear adj spring woth +2 rear swing and +4 rear axel. I do alot of sand drag and flat track drag with the occasional trail ride. Wats the best adj for my setup. I usually sit at 15 clicks clockwise but want better tuning. HELP.
the harder the ground is the harsher youll want your ride helps to keep from flipping over on hard and helps dig in and get a good lanch in sand so turn it to the plus side for hard packed and drop your ride height down. 3 clicks from all the way on plus side hope that helps
