zinger nation Posted August 26, 2008 Report Share Posted August 26, 2008 what will run better???cub with a basic clean up port stock stroke vs 4mill with stock ported cylinders?? : Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted August 26, 2008 Report Share Posted August 26, 2008 well it depends on what your idea of run better? A well rounded motor? A drag only motor? a MX motor? What kind of riding are you trying to do? Quote Link to comment Share on other sites More sharing options...
zinger nation Posted August 26, 2008 Author Report Share Posted August 26, 2008 well it depends on what your idea of run better? A well rounded motor? A drag only motor? a MX motor? What kind of riding are you trying to do? first i like to play on the dunes run through bowls as fast as i want not as fast as i can. second i like to be the first on on top of the hill. Quote Link to comment Share on other sites More sharing options...
Hilarious Posted August 26, 2008 Report Share Posted August 26, 2008 why not build a 4mm cub engine? Quote Link to comment Share on other sites More sharing options...
zinger nation Posted August 26, 2008 Author Report Share Posted August 26, 2008 well heres the deal was gonna do a 4mill, somehow i ended up with a brand new cub stock stroke. the crank thats in there is a hot rods i installed not to long ago, thats kinnda why i ended up with this cub. not complianing thougth. i just couldnt justify redoing the bottom agian, its pretty solid. maybe this will give me the best of both worlds. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted August 26, 2008 Report Share Posted August 26, 2008 maybe this will give me the best of both worlds. Well if the best of both worlds is ON or OFF then it will. If all you do is dune or drag race then you should be ok. Quote Link to comment Share on other sites More sharing options...
slc_hillshooter Posted August 26, 2008 Report Share Posted August 26, 2008 Well if the best of both worlds is ON or OFF then it will. If all you do is dune or drag race then you should be ok. Being from syracuse, you know where we ride bro. Cub is the only way to go and the banshee HQ philosophy of the "light switch" is wrong. With the right nozzles,needles and gearing you will be more than happy. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted August 26, 2008 Report Share Posted August 26, 2008 Throw some compression and timing at the cub, you'll be fine. It is a light switch....but if you add the above, the light switch comes on sooner...and CPI is a good choice of pipe for it...it will make better power over a broader range than a Shearer type pipe will. You can shave the flywheel as well to get on the pipe sooner...too. Quote Link to comment Share on other sites More sharing options...
zinger nation Posted August 26, 2008 Author Report Share Posted August 26, 2008 Throw some compression and timing at the cub, you'll be fine.It is a light switch....but if you add the above, the light switch comes on sooner...and CPI is a good choice of pipe for it...it will make better power over a broader range than a Shearer type pipe will. You can shave the flywheel as well to get on the pipe sooner...too. ya i think think its gonna run pretty good. i have coolhead 18cc domes, 35.5 mukunis, lightend fly, fmf sst they have great bottom i love those pipes, v3, +5 timming, k&n pods, pro design water impeller. my other bike has been ported with cpi's like that one on the hill for now, but then i'll drop a 4mill in that one in the future. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted August 26, 2008 Report Share Posted August 26, 2008 Try the FMF pipes then the CPIs on that cub. I'm not saying it won't run on the FMF...I think it'll run much better for your application with the CPI....you have the luxury of trying both!!!. Good luck, let us know what you end up with! Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted August 26, 2008 Report Share Posted August 26, 2008 Cubs and FMF in the same sentence??? Quote Link to comment Share on other sites More sharing options...
slc_hillshooter Posted August 26, 2008 Report Share Posted August 26, 2008 Cubs and FMF in the same sentence??? LOL yeah dude, what's up with that. Quote Link to comment Share on other sites More sharing options...
zinger nation Posted August 27, 2008 Author Report Share Posted August 27, 2008 LOL yeah dude, what's up with that.ya i will try them both. for what i do those fmf's rock. I'll let you guys know. Quote Link to comment Share on other sites More sharing options...
Animalman294 Posted August 27, 2008 Report Share Posted August 27, 2008 Ya, you'd be happier with the CPI's on that thing.............. Quote Link to comment Share on other sites More sharing options...
Bansh-eman Posted August 27, 2008 Report Share Posted August 27, 2008 Ya, you'd be happier with the CPI's on that thing.............. Correction. The motor would be happier. He might like the way it runs restricting it. Quote Link to comment Share on other sites More sharing options...
