907banshee Posted August 26, 2008 Report Share Posted August 26, 2008 why is it so expensive? Quote Link to comment Share on other sites More sharing options...
Hilarious Posted August 26, 2008 Report Share Posted August 26, 2008 why is it so expensive? good quality, aftermarket parts usually are not cheap. there are a lot of pros to getting a lockout clutch cover even if you dont have the lockout unit. main reason being able to adjust and change the clutch without having to drain the coolant and pulling the entire cover off the side of the engine. Quote Link to comment Share on other sites More sharing options...
kawiking Posted August 26, 2008 Report Share Posted August 26, 2008 ive heard of people sayin the lexan glass one tend to leak.... 907 .. are u lookin at gettin a lockup ? i just ordered a slingshot lockup for mine, it fits under the stock cover. pm dajogejr about them, he runs one on his 10 mil Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted August 26, 2008 Report Share Posted August 26, 2008 ive heard of people sayin the lexan glass one tend to leak.... 907 .. are u lookin at gettin a lockup ? i just ordered a slingshot lockup for mine, it fits under the stock cover. pm dajogejr about them, he runs one on his 10 mil The Direct Drive Die Cast cover is a 100% new casting. Much better alternative than milling a stock cover down and welding or epoxying on the extension ring. The new direct drive 12 bolt lexans dont leak. You can also get an aluminum cover so you dont have to worry abou the clear lexan. Quote Link to comment Share on other sites More sharing options...
Hilarious Posted August 26, 2008 Report Share Posted August 26, 2008 ive heard of people sayin the lexan glass one tend to leak.... 907 .. are u lookin at gettin a lockup ? i just ordered a slingshot lockup for mine, it fits under the stock cover. pm dajogejr about them, he runs one on his 10 mil mine is going on its 3rd riding season and it has not leaked yet. :thumbsup: Quote Link to comment Share on other sites More sharing options...
kawiking Posted August 26, 2008 Report Share Posted August 26, 2008 well there u go.. lol i wanted one with the lexan cover... but damn they are high. plus i wanted to try out the slingshot. doesnt the dd ones stick out alittle ?? i was also worryied about the dreaded kickstart kick back. my buddy went threw 2 side covers with a kickstart prob... id didnt want to risk f n up a high dollar cover... i think badassbanshee sayed there is a mod to prevent that. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted August 27, 2008 Report Share Posted August 27, 2008 well there u go.. loli wanted one with the lexan cover... but damn they are high. plus i wanted to try out the slingshot. doesnt the dd ones stick out alittle ?? i was also worryied about the dreaded kickstart kick back. my buddy went threw 2 side covers with a kickstart prob... id didnt want to risk f n up a high dollar cover... i think badassbanshee sayed there is a mod to prevent that. I believe dajo said that there is 2 different sling shots. One replaces the stock pressure plate, that one fits under the stock cover. The other style uses the stock pressure plate and sticks out a little and requires a cover. That is the one that Dajo is using. Direct Drives new diecast cover also has a beefier area around the kick starter. The cover does stick out a little. I had to do a little grinding on the foot peg and tweeked the brake lever. Plus no vent or rubber plug in the water pump cavity. Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted August 27, 2008 Report Share Posted August 27, 2008 Here is there web page. http://www.directdrivecnc.net/banqcm.html In this pic you can see the seams of a moded stock cover. I posted it so you could see how much they actually add. I just had my cover powdercoated black. Quote Link to comment Share on other sites More sharing options...
shogs Posted September 7, 2008 Report Share Posted September 7, 2008 Does the lockout clutch make it easier to shift? Would it be good for trails or is it meant for racing? Quote Link to comment Share on other sites More sharing options...
Hilarious Posted September 8, 2008 Report Share Posted September 8, 2008 Does the lockout clutch make it easier to shift? Would it be good for trails or is it meant for racing? no. it will make it harder to shift under power. they are best used in conjunction with an override trans for drag racing and hard duning. Quote Link to comment Share on other sites More sharing options...
yamaha11 Posted September 8, 2008 Report Share Posted September 8, 2008 no. it will make it harder to shift under power.they are best used in conjunction with an override trans for drag racing and hard duning. i have a nice lockup and cover for sale if interested Quote Link to comment Share on other sites More sharing options...
dajogejr Posted September 9, 2008 Report Share Posted September 9, 2008 I have the slingshot that fits under a modified (extended) cover. It works. Quote Link to comment Share on other sites More sharing options...
banshee332 Posted September 11, 2008 Report Share Posted September 11, 2008 (edited) I have the slingshot that fits under a modified (extended) cover.It works. same here I ran a dd on mine last year, and it seemed to slip on the big end. Edited September 11, 2008 by banshee332 Quote Link to comment Share on other sites More sharing options...
POORBOY350 Posted September 23, 2008 Report Share Posted September 23, 2008 Here is there web page.http://www.directdrivecnc.net/banqcm.html In this pic you can see the seams of a moded stock cover. I posted it so you could see how much they actually add. I just had my cover powdercoated black. thats perdy... some perty oil in there. mine is different. what kind of oil is that? Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted September 24, 2008 Report Share Posted September 24, 2008 Silkolene Comp Gear It is the best oil I have found. It stays cleaner a lot longer than other oils I have tired. josh Quote Link to comment Share on other sites More sharing options...
