mercado111
Contact Methods
  • Website URL
    http://
  • ICQ
    s. cali
    95 banshee: k&T +4mm stoker, shearer inframe pipes, 35mm air strikers, V-force 2 reeds, and +8 timing. 03 banshee: 10mm A&S cheetah, CPI big bore out of frame, 39mm pwk, V-fore 3 reeds, +8 timing
mercado111's Achievements
HQ Soldier
HQ Soldier (2/5)
  1. will trade for a rator 700 or 06-07 honda 450.
  2. 535 cheetah motor 10mm stroker crank Ported by A&S Sheare out of frame drag pipes(bare) V-Force 3 Direct Drive Lock-up clutch K&T 2-5 overirde trans. 38mm Carbs(gas) K&T upgrade coil Front Marvin Shaw Coil over shocks Rear Comp. Marvin shaw Shock +14 Metal tech Swing Arm (honda style carrier) Aluminium oversized radiator K&T Aluminium gas tank with dual pingel Skat trak 12 paddle buffed rear tires Front buffed tires $6500 PM me with any questions or more pictures Located in so. cal
  3. bump. Will take $3000.00 for the motor.
  4. Trade for a yfz450 or TRX450 and some cash. 535 cheetah motor 10mm stroker crank Ported by A&S Sheare out of frame drag pipes(bare) V-Force 3 Direct Drive Lock-up clutch K&T 2-5 overirde trans. 38mm Carbs(gas) K&T upgrade coil Front Marvin Shaw Coil over shocks Rear Comp. Marvin shaw Shock +14 Metal tech Swing Arm (honda style carrier) Aluminium oversized radiator K&T Aluminium gas tank with dual pingel Skat trak 12 paddle buffed rear tires Front buffed tires have extra set of 39mm carbs and fuel pump that can be converted to Alky PM me with any questions or more pictures Located in so. cal
