MO Banshee
Contact Methods
  • Website URL
    http://
  • ICQ
    Peculiar Missouri
    2001 FMF Banshee, Gnarly's, K&N, Nerfs, White and Black
MO Banshee's Achievements
  1. Got1Banshee Exactly what I am talking about you pull start it and she runs fine. What did your friend do to fix the problem
  2. Carbs are bone stock no body has touched them. Idles perfect once started. I think I might take the carbs off and clean them. I have heard that if the reeds are getting stiff that they won't allow enough air fuel mixture in to start and maybe thats why when I have someone pull start me it turns over faster and creates more vacuum than the kick starter generates. Thanks for your help.
  3. I have a 01 Banshee FMF Gnarly pipes and K&N Filter. I am confused why the thing is so hard to start after it sits for a couple of weeks. I have checked the compression 120 in each cylinder which is right on for my elevation. I pull start it and once it fires it runs perfect. No miss no hesitation no nothing. After I ride it for a while. I can shut it off turn the gas off and leave it sit for a couple of hours and it will start in 1 kick. I have installed a new coil and spark looks good. Choke appears to be working properly. Carbs are in Sync. Curious if maybe it is the Reeds? Help my right leg can't take much more.
