locogato11283
Admin
Everything posted by locogato11283
  1. It’s supposed to be able to slide in and out. That’s normal. Slides need to be synced. Then set idle.
  2. Looks like you need the longer cable.
  3. Pump gas to race gas gains are not minimal. What you gain overall from increasing compression and timing and running race gas is a huge increase in power from top to bottom. What does a pump gas 4mm Serval make, 85HP? My race gas 4mm Serval is at 100. 15HP is a very noticeable difference. You will especially feel it when you’re in the trails, where you need that grunt down low. The compression will shine there. There’s a fine line in compression for a drag motor. Yes, you want that RPM, but you also want the torque to get you out of the hole.
  4. Yea, on slow ass MX bikes. Most of those guys probably get a discount or are sponsored too. Or they might sponsor the series. That doesn’t mean they’re good for a Banshee.
  5. They’re fine. You picked the worst ones anyway.
  6. It’s just a regular wheel with reinforcement rings. If you’re needing to run low pressure, better order bead locks.
  7. Just buy the wheels from RMATV and tires from eBay. Then have them mounted.
  8. ITP Baja with reinforcing rings are very strong and much lighter than CF.
  9. 20x10x9 or 20x11x9 CST Pulse are really good tires.
  10. That M8 bolt could’ve come from anywhere. There’s a lot of M8 shit on that frame. Silencer and pipe mounts, front bumper, grab bar, shifter, kicker, etc.
  11. Ohh ok. I thought you meant the carbs. Stack the nerfs. Secure them together. Wrap with plastic wrap. I always use FedEx for bigger stuff.
  12. USPS will give you flat rate boxes for free. You probably need a medium size. Like $15 to ship. Otherwise, cut the big box down. They don’t care what it looks like.
  13. You don’t need any filters. Let the screen do its job.
