This is a great conversation and like the rest of you I am learning a lot. Over my 30 years as a Banshee owner I would like to share the following points:
- Your engine is a pump. It needs a combination of fuel and air to run. An imbalance of any of these 2 components can lead to performance and longevity issues.
- Since you are on a 2 stroke, let’s define fuel as a combination of Oil and Gas. Air is the 3rd component.
- Your carbs have a pilot and a main jet where a combination of gas and oil flow through them.
- When I was a youngster, I used to think more oil made my motor run richer. This is incorrect. Gas keeps your motor cool, oil is there to lube your parts. (Think of a 4 stroke motor, you don’t put oil in your gas tank). The more oil in your gas/oil mixture the leaner your motor is running.
- With the above said, after an engine rebuild, I will always run a little extra oil in the gas for extra lubrication. I will do this for the first 3 tanks of fuel and then back to my normal gas/oil mixture.
What I have learned. I used to mix 20:1, then 32:1, then 40: 1 and now 50:1. I feel 50:1 is a comfortable balance of a gas to oil mixture for the modded Banshees I own. We want to keep our motors lubricated thus we want to use the right amount of oil, not too much, not too little. The oil you buy should have a recommended gas/oil listed See what they recommend (Call the manufacturer if needed) and use this as a starting point. Whatever you decide on for a mixture, always remember to verify your jetting.
