I can't resist any longer....
A reworked stock head can perform very well. I use the term 'reworked' because simply milling the stock head only raises the compression and can yield a too tight squish clearance.
Brandon 'reworks' the head the right way as I understand. Nothing wrong with that.
Stating firm temperature, horsepower, or power curve numbers is impossible since there are so many variables. I could say "My xxcc xxmm bore xx degree domes with a xx wide squish area in a Banshee with xx carbs and xx jets and +xx timing will run 20 degrees cooler on a 95 degree day when the barometric pressure is 29.90. It might sound really intelligent to someone (probably not) but it would be BS.
The head I've been making for over ten years does cool the cylinders evenly and doesn't allow the coolant to just flow across the top of the domes. The combustion chambers need to be hot to function properly.
Bling, cooling, good and fairly unlimited chamber design, and ease of changing the chamber are the strong points of a billet head. It's not even limited to billet heads. There has been, and will be more, cast heads that use interchangeable domes. Stay tuned.
-David
