Here is an order of events.
First I rebuild top end when I first purchased as it was not running. I did new cylinders (stock) new pistons and head (oem stock) and rebuild the carbs to stock pilots and mains, needle on 3rd clip. Bike would not fire at the time so I tested for spark, compression and did leak down. All tested good. I pull the carbs again and cleaned them really good (again) and went 2 turns out on air screws and 3 turns in on idle screws (tors delete). Bike finally fired and ran great at this point but then got stuck in 1st gear. It only ran for about 15 minutes before this happened. So the following weekend I took off the side cover, fixed the star, replaced the clutch and put it back together. It didn’t start kicking it. So I pushed it and got it to fire. Went around the neighborhood for 5 mins tops with no coolant. I turned it off and heard a sizzling sound. Since then, I’ve added coolant and did a oil change. Now it won’t fire by kicking it or even pushing it. So I ordered new carbs on amazon (MOTOKU) brand. Installed and still no Luck.
