the boris
    3
Everything posted by the boris
  1. Is this your first 2 stroke? Sent from my VOG-L29 using Tapatalk
  2. You might either try some race gas or go to bigger size domes. 155psi is high compression for standard gas I suppose. Sent from my VOG-L29 using Tapatalk
  3. Looks like angry wasp, I bet it sounds lik it too Sent from my VOG-L29 using Tapatalk
  4. That's 20 000 Aussie micro pesos Sent from my VOG-L29 using Tapatalk
  5. I bet it does. A guy was selling his drag shee on gumtree here, asking $15g for it, saying he spent well over $20 on it, with the whole list of parts. He wasn't bullshiting. Sent from my VOG-L29 using Tapatalk
  6. BTW what's the compression? Sent from my VOG-L29 using Tapatalk
  7. Go to 21cc domes or to higher octane fuel. Sent from my VOG-L29 using Tapatalk
  8. Wouldn't have a clue but very curious. Sent from my VOG-L29 using Tapatalk
  9. And yeah, how much HP did it make? Sent from my VOG-L29 using Tapatalk
  10. Looking to hear from the "gods" of BHQ - builders, tuners, and just plain rich people with the taste for banshees. What was your most outrageously expensive banshee build? Sent from my VOG-L29 using Tapatalk
  11. The list goes on and on, depends on how much are you willing to spend. From $0 to $10 000. Sent from my VOG-L29 using Tapatalk
  12. That's stupid, bhq is closed group wtf is fb about. If it's closed group with +18 users bad lingo shouldn't matter. Outright ridiculous. Sent from my VOG-L29 using Tapatalk
  13. Why is that? Sent from my VOG-L29 using Tapatalk
  14. I'm quite illiterate when it comes to that, maybe dynamo shop owners could chip in on this one. Tuners know can make very accurate educated guess when it comes to that, I don't even know what is the stoc motor HP. Sent from my VOG-L29 using Tapatalk
  15. Timing plate and cool head with 21cc domes, you can also chuck in there v force 4 rids. Timing plate being the cheapest Sent from my VOG-L29 using Tapatalk
  16. Got banned from there some 9 years ago, any way of getting back In? Sent from my VOG-L29 using Tapatalk
  17. Thanks mate, makes sense to keep it simple. Sent from my VOG-L29 using Tapatalk
  18. Any cold from 100f (40c) down to 40f (5c), seams to have no impact on difficultie of starting. It only started doing that after the rebuild, but I did change the set up so I knew the jetting wouldn't be right. I will try smaller pilot and see how it goes. Now when I go down with pilot should I go up with main to avoid getting lean on the top end? Sent from my VOG-L29 using Tapatalk
  19. Have trouble starting when cold,once hot starts no problem and pulls like raped ape. Sea level summer California temps K&N air filter FmF fatties Stock bore and stroke Stock carbies 30 pilot and 290 main, needle in the middle +4 timing Cool head with 21cc domes It's running rich but I'm not sure where, bottom, mid or top. Sent from my VOG-L29 using Tapatalk
  20. Does it come to hard stop in the same spot every time or? Sent from my VOG-L29 using Tapatalk
  21. The rod is pressing against that flat part of the actuator, thus preventing you from pulling it out. Sent from my VOG-L29 using Tapatalk
  22. There is the diagram, have a look Sent from my VOG-L29 using Tapatalk
  23. I think you would have to take the clutch preasure plate off to pull the arm out. Sent from my VOG-L29 using Tapatalk
  24. I'm not very experienced but I'm running 21cc domes on standard engine with 4 degrees timing advance and pushing out 135psi of compression. I was advised by members here to leave it at 4 degrees as it would cause predeto if I go more. Sent from my VOG-L29 using Tapatalk
