the boris
    3
Everything posted by the boris
  1. Thanks for the info,found his website, quite informative. Sent from my ONEPLUS A3000 using Tapatalk
  2. That's what I was thinking to do in spare time ,just for shits and giggles. Sent from my ONEPLUS A3000 using Tapatalk
  3. Anyone know where to get them,was looking around but not much luck. Sent from my ONEPLUS A3000 using Tapatalk
  4. Btw compression is a bit low Sent from my ONEPLUS A3000 using Tapatalk
  5. Tell him to check carburettors float level Sent from my ONEPLUS A3000 using Tapatalk
  6. Carburettor flooding? Sent from my ONEPLUS A3000 using Tapatalk
  7. That banshee is more of an investment now. Sent from my ONEPLUS A3000 using Tapatalk
  8. And Sent from my ONEPLUS A3000 using Tapatalk
  9. Got few of those for my old car,found they work well on banshee too. Sent from my ONEPLUS A3000 using Tapatalk
  10. 100x^ what he said. If you are really craving banshee ride,get one that's already running. Sent from my ONEPLUS A3000 using Tapatalk
  11. Electrical shit is just like that,works perfect and you shut it off and that's it,99% of times dies at shut off or start up. Sent from my ONEPLUS A3000 using Tapatalk
  12. Btw that Guy was first grade crook, stealing customers ATVs , really? Was he on some drugs or what Sent from my ONEPLUS A3000 using Tapatalk
  13. FB is mainstream nowadays,this place is dead more or less,if you wanna trade go to FB but if you need relevant info on every single issue that banshees have ,come here and hit the search button. Sent from my ONEPLUS A3000 using Tapatalk
  14. Any luck. Sent from my ONEPLUS A3000 using Tapatalk
  15. What is the old one made off? That's quite risky thing to do and I would highly recommend not to do it. If the old gasket is made of metal I assume you can get away with using Hight temp gasket maker, I did on the turbo car running 22 psi,but that was because it was my only car and I had to wait 2-3 weeks before getting new gasket, I replaced it as soon as I got it. Sent from my ONEPLUS A3000 using Tapatalk
  16. Banshees run resistor spark plug caps so most likely they are shot from sitting for too long (happened to me),buy new ones as they are cheep or you can buy non resistor caps bit then run resistor spark plugs. Sent from my ONEPLUS A3000 using Tapatalk
  17. And this is key override, I just soldered vires together and put the cap Sent from my ONEPLUS A3000 using Tapatalk
  18. This is tors box,mine is just unplugged Sent from my ONEPLUS A3000 using Tapatalk
  19. I had similar problem but in my case was faulty spark plug cups ,they have resistors inside and they went kaput. Just something to keep in mind in case everything else passes the test and turns out to be good. Sent from my ONEPLUS A3000 using Tapatalk
  20. That's right, it's on its own,it doesn't plug anywhere. Sent from my ONEPLUS A3000 using Tapatalk
  21. Took me a while to figure out how to find this thread Sent from my ONEPLUS A3000 using Tapatalk
  22. Hi muchachos,how is going? I'm back and just came to apologize for being a dick. Booxzzy Sent from my ONEPLUS A3000 using Tapatalk
  23. To be honest I'm not sure, I'll have to check that too Sent from my ONEPLUS A3000 using Tapatalk
  24. Top hose on the expansion tank? Sent from my ONEPLUS A3000 using Tapatalk
  25. It's not stupid question. You need to have kit with rubber plugs,caps and pressure gauge. Sent from my ONEPLUS A3000 using Tapatalk
