T13
    3
Everything posted by T13
  1. I run a -2 inch on my banshee with a stock shock and an adjustable lowering link. It works awesome in the corners but can get a little sketchy on the starts if you don't slip the clutch enough.
  2. If you removed the shift forks from the shafts you may have mixed them up putting it back together. This will prevent you from being able to seat the transmission shafts in the cases.
  3. Those look like older Lonestar racing a arms. I have lsr on my yfz450 they have that same logo. this is a pic from ebay of a lsr steering stem. look at the logo on the key switch plate.
  4. Your detonating. You need higher octane fuel, less timing or less compression to stop plugs from backing out
  5. GPR makes a stabilizer and mount kit for the banshee.
  6. F.A.S.T. or South Texas Banshee sells adapter plugs to be able to run square plug cdi's on round plug harness's
  7. http://i925.photobucket.com/albums/ad97/4traxman/100_0401-1-1.jpg These were said to power pro pipes. they look similar
  8. I don't think those are vito's. The set I have are stamped Vito's.
  9. Factory 43 makes a nerf bar for the banshee. Might need a shorter shifter. Peg location is not stock
  10. says part fitment on this is for a yamaha tw200
  11. something about that seems off. when searched through partzilla I come up with https://www.partzilla.com/product/yamaha/3GG-85510-01-00?ref=9d077fe5f70ab4305de8d5fc6f798023ed59f9a4
  12. that's cheaper. I've had longer wait times with their shipping. RM/ATV typically is 3 day shipping for me.
  13. Rocky Mountain ATV has good price free shipping. Yamaha parts nation has better price no free shipping.
  14. I have tried it, it works decent but i couldn't get all the white out of the real bad/stressed areas.
  15. Where did you get your chrome done? I'd like to get my set plated.
  16. Looks great!! How much clearance is there between pipe and the upper a arm?
