Brandonb028
Brandonb028's Achievements
  1. It's not getting any spark for some reason is there anyway to test the coil??
  2. Tried the hose and tried kicking and pull starting again with no luck. It doesn't even really try to fire it just pops really bad. Installed new plugs(without hose on) havnt tried new plugs with hose on now. New plugs are very black also. New plugs again with hose on?
  3. It didn't get hot enough to blow it up I Mean it tried to bump it and back fired and fell on its face and i stopped. Didn't let it over heat. Have 110psi ish on both cylinders on compression t st also
  4. No super long. What kind of damage are we talking?
  5. Yep. Not able to give me a call are ya lol
  6. Ok gotcha. Then there right throttle works fine slides easy.
  7. I already had them plugged in I can try unplugging them. I don't see that dot on the slide ether in the picture. Is it only on one slide? If so which one?
  8. Pic won't upload. What does this do unplugging it? Unplug the tores also?
  9. All three? Thought there was only 2. I only unplugged 2 so if there if a third it should still be connected.
  10. Just for kicks and giggles how do u know what slide goes on what side
  11. Yep marked the slides also. Left the main and pilots the same since the rebuild kit came with stock ones since these ones where not
  12. Yep I kept them separate when I re did them
  13. Just put one on and still won't kick start
