13HemiRam
Everything posted by 13HemiRam
Thanks for the tip!
From a 450? I think I might still have one laying around from my Honda 450 days
I've only had it for a month and it was my first time out riding it. Never even thought to look inside there. Going to pick up a nice used one tomorrow Sent from my iPhone using Tapatalk
So this happened today... It appears that a piece of the spring broke off and got wedged inside the throttle housing. I was half way up a hill in 2nd gear when she stuck wide open. I didn't have much time to think because the front end was coming up, the top of the hill was getting closer and there wasn't but about 20 yards til I went back off the other side of the hill. So I grabbed the clutch and both brakes and after what seemed like 2 minutes of fighting it she finally bounced to a stop. I reached for the key to shut it off but not until she free revved for maybe 3-6 seconds. It was the fastest I've ever heard anything rev and I'm honestly surprised it didn't come apart. It was loud and just about rattled my teeth out from the vibration. My ears were ringing after I shut it off and the guys I was riding with said it was very loud from about 100 yards away. I should have just reached for the key in the first place but I panicked a little. It was fine to ride home and still ripped hard but I hope I didn't do too much damage. It only has 5-6 hours on a brand new motor top and bottom Sent from my iPhone using Tapatalk
I'd probably be interested in making a deal for some stock parts for the pwk's. where are you located?
The athena cylinders are fairly new. Maybe 4-5 hours on them. I'm just afraid of the thin coating that flakes off and the cast pistons breaking. That's my only reason for wanting to take it apart. I kind of want this bike to just be something fun that I can get out a few times when I get an itch for speed or when the 450 and raptor guys start talking shit and hopefully shut them up with it. I ride a rzr900 most of the time, I'm just not into beating myself up ripping a 2 stroke around for hours at a time anymore
This quad also has pyramid reeds, 35mm pwk carbs and t5's. How well, or not so well, will these work with a trail ported stock cylinder setup?
What exactly makes the athena cylinders so crappy? I don't know much about them or even 2 strokes in general, I'm coming from a bone stock 450 to a banshee so this is all new to me. I briefly had a banshee about 10 years ago that was pretty much stock and I wanted another one and ended up with this one (pretty much free) when I sold my camaro
Maybe I'll just sell the athena kit and my pwk's and get stock cylinders and carbs then. I shouldn't have much money, if any, into stock parts after selling mine. I just don't want plated cylinders, it's easier for me to get them bored/honed locally than send out for recoating
I'm starting to lean towards doing something with the athena cylinders since I have nothing into them. If I had to buy them I'd just get stock cylinders but I pretty much got the athenas for free. Vito's makes a sleeve for the athena cylinder which I think is a much better option than getting them replated. So I'm thinking if I get the sleeves put in and have them trail ported that should fix the issues people have with the athena cylinders and it should still make some decent power and I won't have a whole lot of money into them. I haven't been able to find any info on ported athenas though so I don't know if this is even a good idea
I'm also contemplating having the athena cylinders sleeved and ported to make them much better, since I have no money into them as they are, putting a couple hundred bucks into them to make them badass isn't as bad as paying 700 for them first
Hey guys..I picked a banshee up on trade and it has an Athena 392 kit on it. I'm looking to go back to stock. Does anyone know if the niche cylinders are sleeved and can be bored/honed if needed? Or are they plated like the athenas? Are they much different than stock, such as porting and such? I don't need a race bike or anything I probably won't ride it more than a few times a year, I just want it back to stock. My other option is buying used stock cylinders, there's a bunch locally on Craigslist. Let's hear some opinions on this, I haven't been able to find much info on the niche cylinders online Thanks
So my basket does have some play in it. It "spins" back and forth a little bit like maybe an 1/8 inch or so. The clip is still on the idler gear and it has some movement on the shaft but I wouldn't say it's excessive. Is that normal for the idler gear or should it be pretty tight on the shaft? I assume the basket moving isn't good though, so what are my next steps with that? Repair or replace the basket? Thanks
Thanks for the replies. When I get some time I'll pull the clutch cover and check it out
I'll also add that after it cooled down I started it back up and the noise wasn't there until I revved it up and it dropped back to idle then the noise came back, still only at idle, when revved up it still goes away
I just got my roundhouse swingarm on and everything back together today and I wanted to take it for a spin to make sure everything was good. I fired it up and made a lap around the yard, all was good. Then I shut it off and checked everything one more time. Fired it up and starting riding again, still good. I stopped and got off to turn the quad around and I started hearing this knocking or rattling sound. It seems like it's coming more from the clutch side of the engine and only does it at idle. When I rev the bike up it seems to go away and that's what has me stumped. I'm pretty new to banshees so I'm not too sure what it might be. It has about 3 hours on the new motor, top and bottom. Also has a big bore Athena kit, which I did not purchase or install. The previous owner had a machine shop build the engine. I wouldn't have wasted the money on the Athena kit. Anyways, my thoughts are maybe something with the water pump impeller, idler gear, kickstarter, or maybe a broken or cracked piston skirt? (since these are junk cast pistons) Any info is greatly appreciated. Thanks in advance. Here is a video of the noise. At 0:22 I rev it up slightly and it goes away then comes back around 0:27 when it drops back to idle.
Got a swingarm, still looking for headlights price shipped
Looking for these parts, stock headlights and stock length or plus 2 roundhouse swingarm, let me know what you have. Thanks
